Question about Indesit W 123 Front Load Washer
My indesit wib101 washing machine stops in middle of a wash with rapid wash light flashing and it hold its water
2 Suggested Answers
  • 157 Answers
SOURCE: i have a flashing red
It may think the door is still open. Check the door switch is not jammed.
Posted on Aug 16, 2010
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
How can I stop the lights from flashing mid cycle and make the machine continue its cycle to the end and drain?
first you need to take off the drain hose that allows the water to pump out and check to see if it is blocked at the part that it connects to from the machine , you could try to blow back the water but if its blocked i doubt it , after you remove the hosing inspect the inside of where it fitted onto , with the cord unplugged from the wall you might be able to use a bit of wire with a tiny hook bent onto it and pull out any blockages . also make sure the water pump is engaging when it goes into the pump cycle .
Aug 07, 2017 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
162 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
