Question about Dell 924 All-in-One InkJet Printer
924 printer paper jam
I have one paper jam in my 924 all in one dell printer, I can't see the paper, how can I open the printer to take the paper out?
Below the opening part to take a copy you open it, the cartridges will move to a side automatically. There you will be able to see the paper.
Posted on May 21, 2008
Non-existent paper jam
There is almost certainly an optical sensor somewhere that either has a tiny bit of paper or dust in it. Try blowing dust out of the insides of the printer with a shop vac set to blow air out. Also try disconnecting/reconnecting the optical sensors throughout the paper path of the printer. Only do these things with the printer disconnected from everything.
Nov 01, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 will not pick up paper and paper jam light on - no jam
did you remove the plastic from the new cartridge?
If so you might just want to try another cartridge,
Mar 08, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam in printer
go here for the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf") good luck!
Feb 24, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam dell 924 inkjet printer
Is there a door or access on the back of the printer? Some printers can be accessed there.
Hope this helps. Bud
Jan 12, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 inkjet printer
remove all paper, open cover and see if you can see stuck paper.....never try to pull out backwards...try to pull out in direction of normal paper travel..if you absolutely have to pull out backwards unplug printer first and be gentle as to not break rollers or gear(s)
May 17, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Inkjet Printer False Paper Jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Mar 30, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Paper Jam
are you getting a jam error?
If not load a letter sized 8.5 x 11" inch sheet of paper or carstock in printer print somthing let paper get about halfway down in printer then uplug printer and plug it back up as it comes back on it will usally rotate rollers forcing the paper out if you used card stock this should be stiff enough to force the smaller paper out
Dec 07, 2007 | Dell 924 All-in-One InkJet Printer
Reading "paper Jam" but no jam-no paper to be found?
dell all-in-one 924 keeps giving message to clear paper jam. There is no paper in the printer HELP!!!!!
Oct 23, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
75 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
