The issue is that you changed to hdmi and the tv does not support it ..now you need to make a hdmi connection on some tv or monitor that supports this kinda cable ...and after that to change it back ..to vga or whatever cable you used...and will work again ..
put the tv on hdmi ..if it has more than one plug ..change it to another cause I sometimes they do not work in all..try the second or 3rd channel
tried all 3 ports, starting to think it might be my hd cable
this is a possibility ...if you used another kind before and so ..try another cable ...but if the tv detects the cable ..it might be just a setting ..usually if ot does not work in one works in the other ..I did got times when it didnt work in all ports for the hdmi ..reset and try again after you get another cable ...do not buy one ..try to borrow just to see if it is it to blame ..and buy one after you see that this is the case
thanks for the help
i unpluged my tv, the other day to move it, now when i put play staion 3 on, its just a blak screen, i reset the playstation, they tell me they have found a hdmi onnection, if i want to use it, i say yes, and the screen is still black when im on hd tv, please help
already tried that, all it does is give me a black screen, when i agree to change in hdmi
did reset when i put it in hdmi its black
