Question about Dell 1100MP Multimedia Projector
Change color setting
We cannot alter the red green blue numbers in color setting. currently we are using the projector for a home theater and the projector does not come close to true color. is there a way to unlock the color settings? the cursor only allows you to exit that screen... we cannot change the rgb numbers which are all set at 50. we tried calling dell tech support but the rep (in india) was not able to help. thanks.
  • 563 Answers
Hi chatnola
The only way to access these settings is through the Service Menu , now if the tech support doesn't want to help you , rather send go to dell.com and send them a e-mail with your request on how to enter the service menu.
Posted on May 06, 2008
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Oct 01, 2014 | Dell 1210S Projector
How do you connect the component video out to a projector with a component RGB video in. i have the adaptor that works with my other unit but not with Samsung HTC550
The HTT550 has Component Video out on three cables and they are color-coded red, green and blue but they are NOT RGB in the video sense.
What model projector are we talking about?
http://www.smarthome.com/777062A/Component-to-RGB-Video-Converter/p.aspx
Feb 19, 2011 | Samsung HTC550 Theater System
All DVD movies are bluish. How to adjust color to be natural?
if you are using component cables, check the cables for correct color configuration to your TV and from DVD Player.Example red to red green to green and blue to blue, if they check out,the possible problem might be a defective cable...
Dec 29, 2009 | Sony Audio Players & Recorders
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Poor picture quality on my samsung HD TV
Hey xf1racer,
Based on the description that you provided, it sounds like you are using a bundled composite video cable to connect your cable box and TV. Composite video cables generally consist of three color-coded cables: one yellow, one red and one white. While the yellow cable is typically used to transmit the video signal to your TV, the red and white cables transmit the right and left audio channels respectively.
Red/green/blue bundled cables however, are often referred to as component video cables - each of the three colored cables is used to transmit a different portion of the same video image from one device to another, and require a second separate cable (typically red/white) to transmit an audio signal.
The primary benefit of using component over composite cabling is that many users may report a cleaner, more brilliant image on their TV as a result. Please keep in mind however that this is not a guarantee that changing from your current set-up to component cables will improve the picture quality on your TV, as picture quality is often based as much on personal preference as it is the actual configuration and settings of the equipment used.
Additionally, many retailers may suggest changing your current configuration to one using HDMI cables instead to improve picture quality even further. Unlike composite and component cables, standard coaxial cables, and S-Video cables which transmit analog signals, HDMI cables are designed to instead transmit uncompressed digital signals. This typically means that more information is available for your TV to process in terms of color hue, color intensity, as well as image resolution. Again, remember that any perceived improvements will be based on both personal preference as well as your home theater configuration.
Should you have any questions or lingering doubts, I would strongly suggest speaking with a Magnolia Home Theater agent at your local Best Buy™ store for more information. Most stores will have similar TV's on display using more than one type of connection, and sales associates are always able to provide additional suggestions if desired.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 10, 2008 | Samsung PCL545R 54" Rear Projection...
Philips theater system dvd/radio/surround sound
I need your exact model number of HTS, and the manufacturer and model number of your television to be of maximum assistance.
There are a couple possibilities:
1) you could have red, yellow, and whites plugged into the red, green and blue slots
2) If you have more than one output (S-video and red/yellow/white, for instance), the signal could be splitting - try unhooking one of the outputs (preferably the S-Video)
For a more detailed solution, send me your model/manufacturer of TV, and the model of Philips HTS.
Feb 21, 2008 | JVC TH-M505 System
Colour problems with projector
In short If the reds show as red, The greens show as green & Blue shows as blue. I would say thats as good as it can project. It's hard to judge color without seeing it for ones self but usually DLP projectors that use a colorwheel do not have perfect color.
Feb 13, 2008 | Office Equipment & Supplies
The color is all off, no red, the green is too much it does not look right
Which inputs are you using? If your using the composite inputs the cables may be switched.
Aug 18, 2007 | Polaroid FLM-4234BH 42 in. LCD HDTV
Dell 1100MP Multimedia Projector Logo
154 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
