Question about Whirlpool Microwave Ovens
I have a brand new over the range whirlpool microwave. There was a grease fire on the range that melted the door, all of the buttons and censor strip things are gone. so my question is can it be repaired and is there anyway to turn the microwave on using the schematic or anything please help!!
  • Whirlpool Master
  • 5,384 Answers
No! You would have to rebuild the entire microwave including the part that produces the radiation (magnetron or similar). Then you need to seal the unit to keep the radiation from leaking into the rest of your kitchen. The radiation leakage would a) result in much slower cooking and b) be dangerous since it could arc with any nearby metal including the stove. Buying a new microwave would be cheaper and safer.
A countertop microwave in a different part of the kitchen might be a better choice.
I wish that I could be more helpful.
(the major parts of the microwave die when they reach ~200 degrees; the housing won't melt until it is much hotter (if I remember the melting points of the common plastics used correctly).)
Posted on Aug 21, 2010
Panasonic NN-CT585S Microwave Oven - door seal melting on inside - only 2.5 years old. Has anyone else had this fault or just please check where the glass meets the plastic on inside door.
The door seal is called the reflector cover. It stops particles of food from being left in the reflector, the square waveguide that is under the plastic seal.
The only thing that I think can cause that is particles of food or grease/oil sticking to it and melting the plastic. I don't think it is a fault from my experience of working with microwave ovens since 1993 for Panasonic and many other brands.
Jan 06, 2018 | Panasonic Microwave Ovens
Samsung over the range microwave oven model# SMK9175ST the microwave part stopped heating
If "everything" works and your microwave just stopped heating, the problem might be with the internal door switches, the high voltage circuitry, or the circuit board or quite probalby your magnetron is dead. If you don't have the technical knowledge to repair microwaves, you should take it to a repair service for diagnostics.
Jul 16, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Grease dripping from bottom of microwave
sometimes when a microwave is mounted above a range some people dont always consider that you have to take into consideration that you have to go by the heat rating guidelines because it will melt the white lithium grease off the gearing and it can possibly melt some of the protective coating from the circuit boards so check if it is rated to be placed above a range and go from there
Jan 31, 2014 | Microwave Ovens
Microwave plug started melting and is leaking what appears to be oil
Replace it. it may have a short near the plug causing it to melt. if the wires touch you may have a fire on your hands.
Nov 10, 2013 | Whirlpool MT4155SP Microwave Oven
I have a whirlpool RM278BXS microwave oven. Inside the microwave oven along the rear bottom is a thin strip of sealant. The sealant is melted/burned in the middle section for about 1-inch long. I can...
Your best bet is to pull out all the old seal you can, and to trim what's firm with a razor blade.
Sand it smooth if necessary, then clean it squeaky and apply new caulk / silicone sealant.
Leave the door open to allow it to dry out overnight.
If it's not repaired, moisture can cause rust, which will lead eventually disintegrate the metal and lead to to arcing and possible fire in time.
Jun 07, 2012 | Whirlpool Microwave Ovens
The push button that opens the door on our Sharp Carousel R-1406F over the range microwave, is broken. We can push it in but it gets stuck. I cleaned it out because it was kind of dirty but it didn't...
It may be the door open button or the door button lever. Sometimes grease is the culprit, other times the surfaces where these two meet get worn, making the door harder to open.
You can find the full service manual free at our site here.
You can find Sharp part at the Sears Parts Direct Web site hereimage-4235112-10659157 or Encompass here.
You can find links to helpful exploded view diagrams and part ordering help for other brands here.
Jan 01, 2011 | Sharp R-1405 / R-140 Microwave Oven
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave display window shows locked!!!!
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
There may be grease or soot on the control panel causing a lockup, and it may need circuit board cleaning / repair or a new keypad.
Sep 01, 2008 | Microwave Ovens
Small fire in above range microwave, now completely dead.
It probably put too much heat in the "innards" of the microwave and probably opened the thermostat or thermal fuse located inside -either on the chassis of the microwave or or the magnetron. If you or a friend is handy and wants to check and replace it, it's not a hard job as long as you play it safe. It will look something like the attached photo. In my profile you can find a link to my site where you can find critical safety & disassembly tips. There will be numbers on the side indicating the temperature and you can take the old one to a local appliance parts store to get a new one. NOTE: The one for the hood fan will read open at room temperature, so don't confuse it with the other two thermostats, which will read closed at room temperature. Post back if you need more help.
Dec 23, 2006 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
