Question about Crosley CR74 Turntable
Haven't used the turntable in years. Went to use it today and the turntable doesn't begin turning when the arm is lifted. Everything else works. Thanks, Al
    Champion:
  • 222 Answers
If this is a belt driven turntable, then you have to replace the belt, as this units gets old the belts loosen up as well.
Posted on Aug 21, 2010
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
May 17, 2010 | Audio Players & Recorders
After sitting unused for many years, I just
Hi, Does the arm have a lever to lift the arm up, also called a cue. I had an arm where it did exactly the same thing and found it to be the lifting device. What turntable is it you have?
May 12, 2010 | Audio Players & Recorders
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
Crosley CR74 Turntable Logo
318 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
