Question about Samsung BD-P3600 Blu-Ray Player
Snowy picture from samsung blu ray player only shows when using disc not WIFI feed. HDMI cable changed with no impact. I also downloaded new firmware and it did not improve. It does not distort the screen; however it shows white snowy dots which get worse with dark scenery no matter what disc is being played
5 Suggested Answers
  • 45 Answers
SOURCE: firmware update
Here's the link to the newest firmware.
http://tinyurl.com/54a9wo
Posted on Jun 15, 2008
  • 3 Answers
SOURCE: how do I update the firmware on the blu-ray player
See the following URL and follow the instructions to the letter:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=BDPS301&upd_id=3977&os_id=7
Posted on Nov 30, 2008
  • 3 Answers
SOURCE: i have samsung bdp1500 blu
Power the system on with no disc
Go to the menu
Go to Setup
Display Setup
Screen Message
Turn Screen Message OFF
Posted on Dec 11, 2008
SOURCE: firmware update for Element Blu-ray player
I had the same problem. You HAVE TO WAIT 5 minutes after you insert the firmware update disc and BEFORE you press enter on the YES or NO option for updating the firmware.
Posted on Apr 29, 2009
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
Picture is great, but no audio?
I have same problem. Works on smart hub but not on blue ray.
Aug 26, 2012 | Samsung BD-E5700 Blu-ray Disc Player with...
My panasonic blu ray wont play space odyssey 2001 the tv says mode not supported, it plays the sound but no picture all other blu ray discs play as normal. Can you help?
I did solve the puzzle what I did was to, disconnect the HDMI cable and reconnected via component video and it worked well. I am still not sure why it wouldn't play with HDMI as all my other blu ray discs played OK.The TV is a Samsung 52in lcd.
Oct 27, 2009 | Panasonic DMP-BD30K Blu-Ray Player
My HDMI cable wont work from my new Blu-Ray player
On the blu- ray player you have to set it to HDMI in the options or else it wont work
Oct 24, 2009 | Samsung BD-P4600 Blu-Ray Player
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
When hdmi cable is plugged in bluray player stops
Since it was stretched check the ontacts on the acutal HDMI connector on the tv and the bd player a pin bent or touching another pin will cause a vast amount of issues
Mar 29, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
Samsung BD-P3600 Blu-Ray Player Logo
373 people viewed this question
Jerry Greenberg
Jerry Greenberg
