User Ricoh aficio mp 2000 can't print asking for log in username and password? I never set any log in details, I have tried Admin,Supervisor with a blank password but not working, please assist
ChatGPT If you're being prompted for a login username and password on your Ricoh Aficio MP 2000 printer and you haven't set any login details before, there are a few things you can try:
Default Login Credentials: The default username and password for Ricoh printers are often set to "admin" for both the username and password. Try using "admin" as both the username and password to see if it works.
Factory Reset: If the default login credentials don't work, you can try performing a factory reset on your printer. This will reset all settings, including any login information that might have been set. However, keep in mind that a factory reset will also erase any other custom settings you have configured on the printer. To perform a factory reset, you can refer to the printer's user manual or contact Ricoh support for specific instructions.
the first time you access http://192.168.0.50 it will ask you for username and password. Type the default username and password. If you don't know try one of these:
Username: admin Password: password
Username: admin Password: No password (just hit enter after you type the username)
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
a username is a unique name which separates users so that they can customize their settings or set up an online account profiles. If you are searching for a default username try
If you are trying to access the router itself via it's IP address (192.168.X.1) where X is usually 0, 1 or 2... The username and password should both be admin if not, try no username with admin as the password, or try admin as the username with no password.
have you tried entering a blank username i.e. enter nothing? and use admin as the password if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
Step 1: Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here. Step 2: Click on the Administration tab.
Step 3: Enter the new password in the Password field and Re-enter to confirm.
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
