Question about Tomtom GPS
My tomtom won't turn on. It has a black screen with writing on it that says power down and has all this other info. Occasionally it goes to the home page that says tomtom and makes the noise like it is starting up but then it goes back to this black screen every time
  • louiseking_1 Aug 20, 2010
    It is charging correctly so it is not a power issue. I don't know how to reset it as I can't see a reset button? I cant play with any settings as I can't get it off the black screen so I can't play with any buttons on the screen at all
  • louiseking_1 Aug 21, 2010
    I can't see a reset button and it is charging correctly. I can't play with settings because it won't move from the black screen even when i TRY TO TURN IT ON AND OFF OR TOUCH THE CREEN
  • 10,515 Answers
There could be few causes for the same :-
1. It could have been gone into power saving mode. Have you played with the settings. You could refer your user manual for the same.
2. If there is nothing wrong with settings, perhaps the charging cable isn't providing power to the unit and it is running on battery power ( and trying to conserve energy by diminishing the screen )
3. Be sure the cable is plugged in securely, the fuse (located in the very tip of the plug) is good, and that the charging indicator is illuminated.
4. Try a master reset.
If all of the above wouldn't solve the problem, it is more often a hardware failure .Firmware issue could be there. But, you need to get the unit repaired in both the situations.
Good Luck!!
Thanks!!
Posted on Aug 20, 2010
  • taran_2005
    taran_2005 Aug 21, 2010
    Thanks for your response!!
    Follow the below link for Reset procedure :-
    http://www.ehow.com/how_5024523_reset-to...
    Good Luck!!
    Thanks!!
My samsung GT-B3410w won't turn on, I press the "on" button, it loads the phone, but then it gets stuck on a black screen with writing " SAMSUNG mob!le" and thats all. What can i do? is there any
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Dec 01, 2012 | Cell Phones
My tomtom is free it turn off by itself and screen goes up and down showing to choose language only. can't go to the navigation applicatio ? Help please
1. open your tomtom as a folder 2. copy all info from tt to a new folder on your computer 3. format tt in fat32 4. download tomtom home and run it 5. make all upgrades that the tthome sais 6. copy the folders with maps and voices from saved ones 7. if restarts or freeze on logo, open tt as folder and delete the file MapSettings.cfg from map folder 8. say thank you
Apr 26, 2011 | Tomtom One XL GPS Receiver
When i turn my samsung eternity on it goes to the home screen but then the screen goes black and turns off. this has been happening for about a week now and occasionally i get it to work, but i dont know...
The screen saver is set to save mode. use the settings functionality of disable or reesatblsih system settings. a possible battery full charge after powering off device completely shoudl provide the capacity to hold splash screens with phone call display all at once.
Dec 04, 2010 | Samsung Eternity Cell Phone
Black screen after windows start up. Power is on system boots up windows vista icon appears, and then the screen goes black.
Sorry you are having trouble. Try this: turn unit on. Press F8 to goto safe mode. Goto control panel. Goto System. Goto Device Manager. Look for display adapters. Remove whatever is listed there (write it down first) Reboot to normal mode. What should happen is that windows will detect a display adapter and install it. let me know if you need more info.
Apr 06, 2010 | Compaq Presario CQ60-220US PC Laptop
Tomtom 720
Make sure you download the lates Home software - probably availalble at www.tomtom.com
After you say yes to conect to the computer and the screen goes black - jut re-press the on button on the GPS while it is still connected to the computer - it will then work. I also try to open the GPS as an external drive which forces the identification of files while TomTom home is working.
Nov 03, 2008 | Tomtom GO 700 GPS Receiver
Tomtom go 720 - Problems connecting to my PC
We just received a tomtom 720. We can not find out how to increase the volume. Thanks.
Oct 20, 2007 | Tomtom GO 700 GPS Receiver
Switch off/on
If TomTom Home isn't installed on the computer, you can go to http://www.tomtom.com/home to download the latest version. You'll be walked step-by-step through the downloading and installation procedures. Once that's installed on your computer, you may continue. - Plug the home charger into the wall and into the home dock - Plug the home dock into the computer through a USB port - Put the unit on the home dock, but keep it turned off - Go to http://www.tomtom.com/4987 - Scroll down to the first download choice "Window Update" - Turn your unit on - Run the file May 06 Update, no need to save it, ignore TomTom Home asking you to update - After the program runs, turn the unit off - Disconnect the unit from the mount, turn it back on, and reconnect it - Go to http://www.tomtom.com/6211 - Run the Clear Flash Tool, no need to save it - Open TomTom Home and click 'Download Your Updates' in the first column at the top if it's not there already - There will be a Program Application available for download, say 'OK' - After item is downloaded it will ask you if you want to install the downloaded items, say 'OK' - Using 'Safely Remove Hardware' icon in your toolbar, safely disconnect your GO 910 - You may need to reset the device once or twice (http://www.tomtom.com/7134) - The unit should now boot up with no problems If you have any further questions or comments, please e-mail or call us at 866-486-6866 Monday through Friday, 8:30 AM until 7:00 PM EST. Thanks again for writing. At TomTom we believe in showing you the way the easy way.
Aug 17, 2007 | Tomtom GO 910 GPS Receiver
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
140 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
