Question about RCA L32WD14 32 in. LCD Television
Rca L32wd14 has no pic or sound green power light just flashs ????????
  • 11,361 Answers
It may be sensing short circuits in the power supply or in the backlight inverter boards, those are the two places you need to check first. Try disconnecting the connector from the power supply to the backlight inverter board to see if it turn on, you just will not have pictures but you should have sound.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 21, 2010
Rca tv model L32WD14 continually turns on and off. What is going on?
You may have failing power supply module or failing main board, you need to do some voltage cheking at the outut terminals of the power supply to see if the voltages come and go.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L32WD14+
http://www.badcaps.net
Jun 12, 2010 | RCA L32WD14 32 in. LCD Television
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
RCA tv on and off
howdmwl,
I don't if you are still online but I would like to let you know how to get you tv repaired.
You find a TV service center and tel them to fix it.
If they are not able to reair it, you take your work order and call 1-877-297-8391 and they will exchange your tv
Dec 29, 2008 | RCA L32WD14 32 in. LCD Television
Won't power up
Look on your deflection board cp150 green capacitor with gold writing on it will have value of 2200uf 16v if this capacitor is bubbled up on top it is bad so replace all 3) cp150, cp111, cp114.
Oct 17, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
Power on but no pic or sound just the power LED blicking green
I replaced the flyback transformer and horizontal output transistor and works great.
Jul 01, 2008 | RCA F36650 36" TV
RCA L32WD14 32 in. LCD Television Logo
175 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
