Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
My Jazzy wheelcair seems to have disabled my battery chargerss. tHE FIRST TO FAIL WAS A PRIDE MOBILY 24V 5A CHARGE WHICH JUST HAS A RED LIGHT ON THE CHARGER, BUT NO EFFECT ON EITHER THE CHARGBER OR WHEELCHAIR WHEN CONNECTED. MY MERITS 24V 5A FAILED SOON AFTER AND IT SEEMED TO AUDILY CLICK WHEN CHARGING BEFORE FAILURE. NOW THE LIGHTS ARE OFF AND DON'T RESPOND WHEN POWERED. FINALLY MY IVACARE 24V 8A BROKE, THE LIGHT TURN ON BUT GO OUT AFTER 5 SECS AND LEAVING IT ON AFTER CONNECTION WITH NO KIGHTS HAS NO IMPACT. CAN YOU EXPLAIN WHATS HAPPENING ORE HOW TO FIX IT?
  • 3,083 Answers
I would suspect a shorted cell in the battery is causing too much of a current drain, and taking out your chargers. Take the battery to an authorized repair facility and have them run a load test on it. It's either that, or a possible short circuit in the wiring harness, in which case it would take some troubleshooting to figure it out.
Check that battery first...it could be your whole problem.
If you suspect your motor is shorted and bad, read the following blog:
Solution #1 posted on Jun 05, 2010
My Jazzy wheelcair seems to - ea1691e.png rulds2008
Rank: Guru
Rating: 87%, 2016 votes
The issue on these is ether the motor has burned out on you or the battery is not getting enough current to turn the motor or you got a bad relay from the control panel to the motor, There is no way to diagnose this without having someone to come out to your home. But I can tell you this much my dad had one of these and his motor was the issue and when you got a motor issue in these mobility devices you might want to concider ordering a new chair if possiable. Just the parts and labor alone is over $1,500 trust me been there done that. So the best thing I can tell you is run test on the chair and if you cannot do that you need someone to visit your home to do that for you the cost to visit is like $125 bucks minium as they got to charge for there gas and there labor when they arrive. I would call the scooter store for a tech i nyour area.
I would guess it's the battery, motor, or relay, in that order. The unit will have to be tested to know for sure. Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 21, 2010
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
Jazzy charge light on chager does not come on
The red light indicates that power to the off-board charger is on. Try a different ac wall outlet that you know works. If a red or green light does not come on you will need to replace charger. Also check the condition of your batteries - dead batteries will not charge.
Mar 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
How long does it take to charge
how discharged is it?12 v.gel cells have to be trickle charged,2a-5a 24 hrs.should do it
Oct 05, 2012 | Pride Mobility Jazzy 614 - Jazzy Red,...
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
Charger does not seem to charge battery. Red light comes on, fan and yellow light start up then shutdown within 3 seconds. Red light stays light. What might be wrong with the charger?
How old are your batteries? Have they been charged regularly? (ie: every night) I have a hunch it may be a battery problem rather than the charger. The batteries should be load tested with an automotive load tester, or you could take the batteries to a local service station to have them tested. If they test poorly, both batteries need to be replaced.
Sep 05, 2011 | Pride Jazzy Select 6 Indoor Power...
Jazzy Select 6, Charge batteries. Green light comes on...run for a few seconds and goes directly to red light. Chair will continue running. One battery shows a charge of 12 volts the other 13 volts. Has...
Hi You need new batteries If you have a battery store near home or an interstate battery distributor have them get you 2 U1 batteries. Charge before use and you should be go to go for another 3 years or so Hope this helps
Feb 10, 2011 | Pride Jazzy Select 6 Indoor Power...
I have a Jazzy Power Chair that hasn't been in use for several years. When I tried to charge the battery only the red light comes on. How do I get the yellow light to come on to show it is being charged?
Retired get new batteries if they haven't been charged for that long they're shot. Invest in 2 good U1 batteries, charge before use and you should be good to go Good Luck
Nov 01, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Pride Jazzy Select batteries not charging
If you use an automotive charger you have to charge each battery individually as they should be 12vdc hooked in series.
Clean contacts and assure yourself that each lead is charging properly. Jazzy has many different models so it impossible to know which you have. But there should be some info on the charger to tell you if your output is 24v or 2-12volt DC leads.
Jazzy has a web site and there is a member section where you can ask questions.
May 16, 2009 | Pride Mobility Products Jazzy Select
Elctric wheelchair, flashing rapidly the error display
Have the batteries load tested and be sure that the chair is in gear.
Feb 03, 2009 | Select Jazzy Used Electric Wheelchair
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
