Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Will not run
Clean light flashing , manual indicates heater circuit problem
  • Anonymous May 09, 2008
    Hi my name is Diego and I am the facilties manager of a youth shelter. It seems that one of the youth left a plastic spoon in the dishwasher and then it melted. I had the same problem 6 months ago with the clean light flashing. I called sears to come out and thought they would replace the element, but instead they punched a few buttons and it worked fine. they then charged me 125$. Is it possible to know what buttons that he pushed?
  • Mrcantfixit May 11, 2010
    Whirlpool DU1100XTP
Hit the bottons twice and now it works great
Posted on Aug 08, 2008
By pressing the high temp wash and heated dry buttons in that order 1 after another will reset the blinking clean light after several times prob about ten times my board reset and dish washer is working fine ty
Posted on Jul 31, 2008
    Problem Solver:
  • 19 Answers
Tech most likely pressed high temp wash then heated dry then pressed high temp wash then heated dry. in that order high temp wash, heated dry high temp wash heated dry. all pressed individually one by one.
Posted on Jun 10, 2008
  • 487 Answers
Than either replace heater sensor or element.
Give me model number pls
Posted on May 03, 2008
3 Suggested Answers
  • 949 Answers
SOURCE: clean light is flashing. Will not operate. suspect heater circuit
This is due to the water not heating properly.
Here is a link to show how to reset the control so you can use it, what may be causing it and how to resolve it.
Posted on May 10, 2010
SOURCE: heater circuit
whirlpool dishwasher won't go into washing cycle
Posted on Mar 07, 2012
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
Oct 11, 2016 | Kenmore Dishwashers
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
I have a Hotpoint SDW 60 problem! The dishwasher starts and goes through pre-wash but stops with just the 'Delicate' light flashing. Does anyone know what the problem may be?
If the original light flashing that means it indicate a fault in the heating circuit. Heater, wiring, thermistor / pcb. (Main control board).
The new flashing light, PreWash (this is the only one on my list for a fault code indication). indicates a fault with the thermistor.
You would need to check by taking the door apart that the thermistor hasn't come off it's mount by the dispenser.
You would then need access to and be able to use a multimeter to test the heater and wiring to ensure they are closed circuit.
Jul 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
I have a Whirlpool DU1055XT. The unit will not work
The flashing light indicates the water is not heating, there could be several reasons for this, I have created instructions on how to reset the dishwasher so you can use it and why it may have occurred. If you follow these and still have trouble let me know and we can dig into it deeper.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool dishwasher model number GU3600XTSY2 is flashing: The clean light is flashing! It's not the heater circuit either. It says the dishwasher is malfunctioned. Call for service to check heater...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Mar 17, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Delicate light flashing will not dry
Post more information about your problem if you need more help....
Good Luck!!
Thanks
Aug 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Model # 665.17032402 Clean light is flashing. Manual says to check heater circuit. How is the heater circuit checked? How is the heater element assembly replaced?
You need to check the thermostats in the heater circuit as well. The element is held in place my 2 nust from the bottom where the wires attach.
eric
Jun 29, 2009 | Dishwashers
Rinnai Energysaver 1004FTR (nat gas) RED FLASHES
The filter light can also indicate a build up of debris and lind behind the heater causing the blower to work harder to push out warm air. It could also indicate that the blower may need a cleaning or going bad. I will suggest that you pull the front cover off of the unit to inspect the blower which is located at the top of the heater. Feel the motor as it is running to see if it is hot. If so, you will probably need to replace it. I may have a used on so let me know. If everything in front looks good, pull the top trim panel off of the heater just behind the filters and inspect for dust. Clean with a shop vac. Hope this helps.
Dec 18, 2008 | Water Heaters
Model GMP100-5-REVA
You could have a limit switch that opened. On the reverse side of the furnace access panel there will be a diagnostic chart indicating what 4 flashes indicate. If it is an open circuit, why is it open? Did the unit get too hot and why? Unless you have the diagnostic capabilities, call a professional.
Jan 04, 2008 | Goodman GMS90703BXA Heater
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
607 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
