Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
My Troy-bilt edger C5 4-cylinder will not start. I've replaced the gasoline and spark plug. This unit was bought on 04/01/2004 and has run good up until this year. Thank you, Ron Smith
  • Troy Master
  • 7,482 Answers
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
My curved shaft gas trimmer by troy bilt tb22 ec wont start
General rule: You need 3 things for an engine to start, fuel, air and spark. Do this test first (fuel)and this will eliminate the need to test for spark or air. Remove the spark plug, spray carburetor spray in the plug hole, a good 3 squirts, don't be afraid it won't hurt a thing. Put back in the plug and try and start the unit. Now if the unit starts to run for 3 to 5 seconds, you have a fuel problem for sure.
Your next step will be to clean the carburetor .. and that is a whole other lesson... BUT, simply go on you tube, type in how to clean a 2 cycle carburetor, you will have a ton of choices. Go with the one that has the most views for aure. Good luck! !
Sep 24, 2015 | Troy Garden
I have a troy built trimmer model # tb65ss
check the kill switch position and wiring, if good, check magneto wire
Jun 30, 2014 | Troy Bilt Tb70ss Gas Trimmer
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
Sep 25, 2013 | Troy-Bilt Garden
I have a weed eater trimmer that wont start. ben sitting for a couple years and i replaced the fuel lines andcleaned the carb. still nothing, what do i do?
Try cleaning the spark plug, make sure it sparks. Put some fresh gasoline in the tank, check start stop switch.
A easy way to check whether the problem is related to carb or not is:
remove the spark plug put some fresh gasoline in the cylinder, put the spark plug back
pull the starter a few times if it starts for a few seconds it means is related to carb.
Be carefully when handling gasoline.
Aug 05, 2011 | Troy Bilt Tb70ss Gas Trimmer
Troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Oct 25, 2009 | Garden
Trimmer won't start after following instructions
Might need a new spark plug if it's more than a year old. I had mine a year and after the winter couldn't get it to start. Replaced the spark plug and it's good as new.
Jun 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Brand new , won't start, no spark at plug, switch ok
If you know for sure that it's not getting fire, then I would take it back to where you purchased it. It sounds as if it has a bad ignition module.
Jim
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
540 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
