SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
If you have an infrared remote and your Direct Tv remote is using an RF signal then you need to call Direct Tv and they will help you program your DVR to the remote.
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
SOURCE: how to clear remote so I can program it again
Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
SOURCE: picture
I assumes that there is a confused memory IC inside, due to improper data inputs. Try a hard reset to this set. Unplug it from AC mains wall socket, and re-plug it back after 10 minutes of so. This must make it a hard reset. If it do not help you, contact any service technician. If you are somewhat sound in electronics and If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
