Question about Kenmore Washing Machines
Re: kenmore thintwin heavy duty manufacturer id 3350600 i have a stackable kenmore washer/dryer. the outer washer tub has a leak at the top from inner tub rubbed against it at one time when not level. i was wondering if can be fixed with an adhesive and patch, but unsure what type of plastic or material tub is made of to chose best adhesive? if i can identify type of plastic i can choose an adhesive, epoxy, etc to apply patch over it.
  • Kenmore Master
  • 1,253 Answers
If you patch the seal, it won't last long. Order a new or used rubber seal boot.
Posted on Jul 03, 2017
3 Suggested Answers
  • 639 Answers
SOURCE: whirlpool thintwin stackable unit
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Posted on Aug 26, 2008
  • 24 Answers
SOURCE: my kenmore heavy duty washer 70 series #3349369 the plastic outer tub is cracked. Can I use some type of waterproof sealant to fix it?
There is no sealant that will withstand these kind of forces.
I'm sorry.
Posted on Feb 23, 2013
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
I have a kenmore stackable washerand dryer that is less than a year old... the problem is that my basket in the washer sits crooked like there is a spring or something off... so now i have to wash minimal...
Yes if its less than a year old call for service it will not cost anything. there are supports under the tub that support the outer tub and basket that have come loose
Oct 05, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a stackable washer and dryer and water leaks out the bottom as fast as it comes in and when i saw it leaking i tryed to spin it to **** the water down the drain instead of the floor and it started...
Chances are that if water is coming out of the bottom very rapidly a clamp or hose has come loose off of the tub or pump. Also, since that is a stackable unit it should be very easy to check. Tilt the machine back and there should be 2 screws or fasteners holding the front panel in place. If it is not a hose the only other thing would be a crack in your outer tub. (It would have to be one heck of a crack too).
Aug 16, 2017 | Frigidaire FEX831CS Top Load Stacked...
I lost 23 small rhinestones from jewelry in washer...
Yes. They can get trap in the pump, if they got in between the inner and outer tub.
Dec 12, 2009 | Kenmore 22422 Top Load Washer
The barrell has come loose on my thin twin stackable washer/dryer
The struts, shocks, springs...they are called different things depending on who you speak to. Apparently on the heavy duty thin twin stackable units they are all bad and last for about 13 months just after the manufacturers warranty, this is common knowledge among Whirlpool technicians and even the replacement parts that are being installed are not performing for the lifetime they were designed. I have contacted a repair service and they are scheduled for the middle of next week and over the phone he ballparked the estimate at about $300.00.
May 15, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
Open Questions:
Washing Machines Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
