Question about Samsung DV337 Electric Dryer
DV337AGG/XAA HAD DISPLAY E5 WITHOUT TOP LINE OF E REPLACE ALL HEAT LIMIT THERMOSAT THERMISTER AND THE INGNITOR WAS BAD HAD A LITTLE FIRE IN IT THAT GOT ALL THIS STRATED AND MELTED SOME WIRES REPAIR THEM NOW IT RUNS FOR A LITTLE THEN TURNS OFF WITH DISPLAY OF E 0 WITH THE TOP LINE?
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 84152 /94152
probably the heater
Posted on Jan 15, 2009
gopakumarg43
  • 74383 Answers
SOURCE: Samsung 42" Plasma #SPR4212X/XAA TV was
Hello
In normal casses, if the power supply regulator board of Plasma Ts cannot be get repaired by any means. The inverter transformer [Switched Mode Power Supply]; will get shorted windings inside it, which cannot be retifed. this is a critical part, that cannot be available at local electronic sparepart market, of as part at Samsung service center. it is best to replace it as card basis, as plasma power supplies must be very right in every respect for the proper working of the plasma TVs. Thie is quite normal case also, that unlike LCD power supply sections, plasma power supplies will get troubled soon, as it supplies more current to the plasma screen to illumitate. Just replace it. You can get it from the Authorised Service Center for Samsung at your town. It will solve your TVs problem. The oscillating frequency of the switched mode power supply of this model of TV you owns have [350kHz] a very high frequency than normal LCD or other Samsung power sections. It will have a high stability, which cannot be accuired by normal service techniques, and components in it will be of special type. OK.
Posted on Sep 03, 2011
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
Why does the f5 display on my ac
Are you sure it is F5 and not E5, F5 would be a error code for a Frigidaire stove. now E5 would be a coil thermistor problem. Check and or replace the coil Thermister
Jun 29, 2014 | Frigidaire Heating & Cooling
Maytag neptune error message e5
This normally indicates that the thermistor is bad. Try measuring it to prove it is OK. It should be 10K Ohms at room temperature (20C / 68F).
If necessary, replace it then clear the error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Sep 06, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer runs, no heat, element OK 10.5ohm, Hi limit thermostat .8 ohm, next one is thermal cutoff or operating thermostat, open no meter readings. Part # FSP 3399848 could this be my problem? Thank You
Both the Thermal cutoff and the operating t-stat should have ZERO ohms resistiance 0.8 is fine but open on either they are bad
That part number you have listed is what ya would need..even if only the thermal cutoff is open replace both the thermal cutoff and high limit t-stat at the same time
also if the cycling t-stat is open replace it too...if its fairly modenr and hasa digital display the cycling thermostat is a thermister and at room temp that will be about 5.8 thousand ohms
if has timer the cycling t-stat will look like the high limit t-stat and should be closed
GENE
Aug 29, 2011 | Dryers
Main blower constant run with t- stat off //No heat
If it is calling for heat the draft inducer it is the first device energized, the pressure switch will want to be proved and then the ignitor will glow and the gas valve will energize and the sensor will prove the flame and the heat is on.
If one of the above is not in the right time and place the rest will not work. About the fan it is either a shorted control wire for the fan or the limit switch (the high temperature limit) is made or bad.
If that is not the case the the thermostat has a switch in the back between the gas fired or electric. That will determine if the fan should be on every call for heat.
Oct 20, 2009 | Goodman Heating & Cooling
I replced ingnitor in my kemore gas dryer but not flame
Hello Friend, If the igniter is glowing continally and not clicking off, then your therm-disc is definately bad. It's attached to the burner shroud right across from the igniter. It reads the heat off the igniter through a little rectangular hole in the shroud. Replace and problem should be solved.
If igniter is glowing and then cools down and then begins to glow again in a repeating manner then I would say that the thermo-disc is good and you need to replace the gas valve coils. coils are easy to change, they are located on top of gas valve, two screws hold them in place. An easy fix.
Happy to help, Tim.
Jun 30, 2009 | Kenmore 75944 Gas Dryer
Error code 126
This is a bad thermister or heat sensor. It mounts in your water manifold and if it goes bad no error will show. The bad sensor is telling the heater that the water is to hot and it wont let the heater fire. This is a farley inexpensive part and easy to change out. With a new one it should read the proper temp and call for heat then fire the heater. Good luck.
Jun 17, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Frigidaire dryer won't heat
the Thermister on the blower box can be bad causing the unit not to heat I had one do that . its a cheep part. take off top then remove front and its in front of blower housing . thanks jim
Jan 20, 2008 | Frigidaire FEQ1442ES Electric Dryer
Samsung DV337 Electric Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
