Question about Philips gemini TT-02 MK2 Turntable
Were can i get parts? the arm holder is broken...
    Champion:
  • 222 Answers
Try partstore.com
Posted on Aug 21, 2010
Why does The bobbin holder keeps 'crashing' with a metal 'arm' on the left.
Hum, nothing should
"crash" into anything else while sewing. The Hook (place where bobbin case snaps into) might have a broken "keeper" (internal part that "keeps" the hook stationary when sewing.) Or your bobbin case may not be installed completely or correctly.
Cheers,
Kelly
May 03, 2014 | Janome Memory Craft 9000 Computerized...
Wipers don't grip rear window
Wiper arms are much neglected for a part that does such hard work. There are 3 main parts, the rubber, the rubber holder which is actually also a sort of spring, and then the arm with its strong spring.
Try replacing the rubber and holder as an assembly which clips onto the end of the arm. This is the most cost-efficient maintenance you can do, and should make a big difference.
The arm and spring can be replaced by undoing a nut under the cover at the top of the wiper arm spindle, but this is far less often needed.
Feb 12, 2014 | 2005 Saturn VUE
Hi. Have a AG4700. When I insert tape, it goes in,stays in for about 5 seconds,and then ejects on its own. At the moment,it is not connected to a television, and I do'nt have operating instructions....
Mine had this - was simply the pinch roller arm seizing on its post due to dried up lube.This prevented the arm from lowering on the spiral cam. I unclipped the plastic holder, removed the pinch arm, cleaned the hole and the post with alcohol and re-lubed with Superlube synthetic grease.Anywhere else you can see black grease should be cleaned and re-lubed as well as the stuff turns into glue over time, gumming up the works.
Aug 11, 2011 | Panasonic AG-4700 VCR
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
How to reconnect upper spray arm bosch model 4300
Welcome to FixYa.
If you align the spray arm to the section of the upper rack which it fastens to, as shown here...
Then place it against the holder and turn, it should grab the holder, unless something else has broken...but it should be that simple.
This is the official explanation from Bosch below...
Hopefully that will help you move forward and answer you question. Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Jan 05, 2011 | Bosch Dishwashers
My top spray arm has fallen off and i cannot work out how to put it together as ive got 2 parts and they dont seem to lock to gether
Welcome to FixYa.
Then place it against the holder and turn, it should grab the holder, unless something else has broken...but it should be that simple, i.e.
Regards,
Macmarkus :)
Jan 02, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
The paper roll holder is broken on one side. Can
For most models, the holders can be replaced. You can try Universal Paper Arm Holders if you can't find one for your specific model.
Mar 25, 2010 | Office Equipment & Supplies
Need cast iron bowl holder assembly for Hobart A-200
if your looking for the bowl yoke goto hobartcorp.com or call 18884hobart for the part number and price.
Dec 30, 2007 | Hobart A200 Stand Mixer
Desperate: Need Part For Sony SLV_940hf
I have a recorder with a different problem. The part you want is good.
Post an email address and I will contact you regarding terms.
Ron
Dec 02, 2007 | Sony SLV-940HF VCR
Philips gemini  TT-02 MK2 Turntable Logo
85 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
