Question about LG 32LG30 32 in. LCD HDTV
Possible to connect Fennec IT-702 B2 external speakers?
What is the best way to connect headphones to a SAMSUNG model #UN32J5003? Also would like to connect external speaker to this unit if possible what will I need?
I bealive this unit has no headphones or rca audio output.
It however has an optical audio connector which can be connectect to most amplifiers to which external speakers are connected to.
Some amplifiers have an audio out 6.35mm plug. Grab an adapter ( 3.5mm to 6.35mm) and you may use your headphones.
Jan 05, 2018 | Samsung Computers & Internet
External Speaker Hookup?
Yes buy RCA cables and connect to round audio out plugs on tv
Jul 28, 2008 | Quasar SP-2725 27" TV
Need the driver for a SMARTDISK model FDUSB-B2 external floppy disk drive unit for a old Gateway Windows 98 computer
Since it is a USB device, does Windows 98 automatically load the device-driver when it is connected? If not, connect to the Internet, and run Windows Update (http://windowsupdate.microsoft.com) and let it scan for updates. When it completes, look at the "optional" updates -- there may be a device-driver that can be downloaded.
Jul 18, 2014 | SmartDisk Fdusb-b2 Usb External Floppy...
I want to install external speakers to my Compaq V2000
There are quite a few speakers on the market of different sound quality. I sugest you get speakers that have a built-in amplifier and you connect the powered speakers into the headphone socket on the laptop. Take you laptop to a computer shop with a CD and or DVD and test it with various speakers and then select one that suits your tastes and budget.
Jun 04, 2009 | HP Compaq Presario V2000 Notebook
External speaker hook-up possibility
Yes, its absolutely possible. You can connect external speakers from analog output of TV. Even you can use AV receivers available in the market which can be used to amplify OR process the tv sound with latest digital processing techniques, it would be very much pleasant than the sound from tv.
--Sandy
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv speakers not working :-(
Many tvs have a connection for external speakers to enhance the sound. If you have a speaker to test that out do that. It is possible it is not the speaker that is the problem, but it could be the amplifier in the TV. You can't lose anything by plugging a small speaker into the speaker out connection to check that out.
Sep 30, 2017 | Radio Communications
External speakers
Unfortunately no. The Panasonic PT-60LCX64 TV does not have any jacks, plugs or external connection point to attach he wires of external speakers.
Alternately however, it is possible to install 2 pairs of speaker terminals on the backboard and wire them in parallel to the internal speakers.
Hope this be of help/information. Good luck and kind regards.
Feb 05, 2008 | Panasonic PT-60LCX64 Television
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
LG 32LG30 32 in. LCD HDTV Logo
98 people viewed this question
