Question about Maytag Neptune MDE6800 Electric Dryer
How do i lubricae/oil the rollers, etc. in my maytag dryer (about 25 years old)?
  • Maytag Master
  • 8,220 Answers
I use Zoomspout oil. It is safe for dryers because it is non flammable, won't dissipate easily and heat resistant. Near as I can tell by looking at your partial model number, that dryer is mostly like a Cabrio dryer. I am gonna post a Cabrio dryer manual just to give you an idea what ya have to do to get into this beast,
Cabrio dryer manual
You can get more info on your dryer by posting a complete
model number at the MAYTAG LIBRARY OF MANUALS
Posted on Aug 21, 2010
My maytag dryer is about 17 years old. It turns on but the drum does not spin
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 07, 2010 | Maytag Dryers
When you push the button to start, the dryer only hums. The dryer is only 2 years old.
Please rate me
Aug 23, 2010 | Maytag MDE308DAYW Electric Dryer
MAYTAG DRYER MOD. # MED9600SQO. Squeals while running. It is 3 years old. When I remove the belt and roll it by hand it sounds fine. Does a bearing in the motor in these tend to wear out prematurally.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 17, 2010 | Dryers
After running for awhile the dryer starts to make a kind of squealing noise and a grinding noise. The dryer is only 3 years old. I have popped the top open and the belt is tight and seems to be running...
Your problem sounds like drum rollers is in need of lubrication.
Now is a good time to check the belt condition for wear.
Good Luck,
I hope this helps
Nov 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer is making a horrible squealing noise when there is a medium sized or larger load in it. it still dries and tumbles but i think a belt or something may be going bad. it is about 4 years old. can...
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 23, 2009 | Maytag Dryers
My Maytag dryer is 14 years old. Now it makes a
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Yes, replacing the drum rollers is fairly cheap especially if you do it yourself, saves you the price of a new dryer for a few more years maybe.
Good Luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
Maytag Dryer, 25 year old dryer has a loud squeak
Hello.
The squeaking is coming from the rollers that the drum rides on. If you take the model number to a local appliance service store they will have the parts and be able to direct you on replacing them.
Jul 20, 2009 | Maytag PYE2300AY Electric Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
While my dryer is running it makes intermittent squeaks.
most of the time your rollers and belt are fine 1st thing to check would be the idler pully which keeps the tension on the belt so the tub spins
Dec 19, 2008 | Maytag MDE7600AY Electric Dryer
Clunking whirlpool drier
rollers and or felts are cheap,
much cheaper than a new dryer,
and nobody now makes a dryer that will last 25 years.
I have maytags 1972, 1974, kenmore 1968, speed queen 1980,
in each apartment building used by 11 families, to keep them running costs peanuts
new dryers?, - 3 years is all you get before the $$$ starts
Oct 04, 2008 | Whirlpool LER4634J Electric Dryer
Maytag Neptune MDE6800 Electric Dryer Logo
113 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
