Question about Daewoo DTQ-14N2FC 13" TV
Someone gave me a 1998 Daewoo 14N2FC TV recently (with an antenna) but so far I do not know how to set it up. All it is showing is white noise when I select setup and go through all the channels with the auto program. After the setup is done, all it shows is a blue screen. I am not skilled in setting up TVs at all, can you help me? Do I need additional equipment like a cord? And can I plug it in to a regular outlet or do I need to plug it in to the outlet that the phone goes in? Thank you!
  • 77 Answers
You will either need a converter box (which hooks up with a normal coax cable in the rear of the tv) or cable/satalite tv hooked up to it in order to get a signal
Posted on Aug 20, 2010
Hello! I recently moved my Toshiba 26lv610u-t from my father's place to my own. It was a short trip as we live across the street from each other. When I connected the cable to the TV, I found that all...
There are no analog channels anymore as far as I know, if you mean the channels that are local and provide an off the air signals, you need to connect an antenna for off the air signals, it may be possible that at your father's place the off the air signal was strong enough to receive them. Try going in to the menu signal type select "Air" to see if that makes a difference, of-course you will lose the cable channels until switch back to "Cable" .Hope this helps, KA
May 07, 2017 | Toshiba 26LV610U LCD TV
Daewoo tv is 7 yrs old. Problem started yesterday. when i switch it on, red light on TV comes on, blank screen. I press the on/off key on the remote, red light on TV turns green, I get picture for 3...
will not know that until you have a proper diagnosis done to determine the damage and if parts are still available
only then can you make that decision
Nov 04, 2017 | Daewoo DTQ-14N2FC 13" TV
Recently purchased a wii and had no av cable input on my tv, so I purchased a component cable, hooked it up, and only got black and white. After spending two hours messing with both the wii settings and...
You can't use component input on the tv. You have to have component output on the wii and it doesn't have it. Are you sure you don't have A/V inputs on your set? I don't know of any set that doesn't in the LCD field, even the cheap imports have them. I tried to cross your model number and it went nowhere. Could you re-check your model number and send it to me. Some models of Insignia had a hidden compartment on the sides by the antenna jack that pops out.
Dec 27, 2010 | Insignia 42" LCD Flat-Panel HDTV
No av ports and can't play video games help
buy a v to rf converter
if fix your problem click yes for vote
Dec 26, 2010 | Daewoo DTQ-14N2FC 13" TV
Need 3 digit code for daewoo tv model number dtq 14n2fc
Daewoo 0 4 5 1 ,0 0 1 9 ,0 6 2 3 ,0 6 2 4 ,0 0 9 2 ,0 0 3 9
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 09, 2009 | Daewoo Televison & Video
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
CHILD LOCK Help needed
Hello i recently had a problem that my tv just locked itself which i think is the same type of problem, i contacted Daewoo and they gave me the following code to try and it worked, not sure if it will do the same for your set, but it might be worth a try.
press the following buttons in the remote in sequence
BLUE
YELLOW
GREEN
RED
STANDBY TO TURN OFF
STANDBY TO TURN BACK ON.
Hope this might help, if not try contacting Daewoo Electronics website and put in your model number.
Regards
H wilson
Apr 12, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
Daewoo DTQ-14N2FC 13" TV Logo
89 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
