Question about Canon EOS-AE-1 35mm SLR Camera
I have a Canon AE-1 camera that I bought off of E-bay months ago. I just recently took the used film to get developed & when I picked it up the film only developed a few pictures, but the rest were blank. I used Fuji film, & I set the film speed and everything where I need it to be. Besides taking it to a repair shop, is there possibly another way to fix this, possibly myself without costing me $?
  • 1,606 Answers
If the camera is actually at fault here (and yes i always blame mine ;-]) it is usually due to the shutter getting out of time with the flip mirror. When you take a picture the mirror flips up out of the way and then the shutter opens and the camera actually takes the picture. What can happen i the track gets gummed up. Can be from old lube or the wrong stuff being used or dust. So when you take the picture the mirror doesn;t get out of the way and you get a picture of the back side of the mirror. I think that has a titanium shutter but older ones had a cloth shutter and those would stick a lot easier.
You can clean the track using isopropyl alcohol and cotton swabs. You need to be careful not to lave any cotton fibres in the tracks or the mirror or the shutter. Take the lens off and then push the mirror out of the way with a swab (don't touch anything in there with fingers) Wet a swab end and just follow the track a few times. It may take a few passes before any buildups start to loosen up. And you may not see much if any thing.
Don't use any lube unless you have a high quality silicon. So don't be tempted to spray some WD40 in there (yes I've seen some do that and then wonder why it doesn;t work). There is a reccomended lube but I'd have to dig out the shop manual for the series to find what it was. It either was a silicone lube or a graphite. Anyway if the cleaning improves or fixes the problem then you should be good to snap away.
Posted on Aug 20, 2010
Advance lever is stuck. I bought new film and a new battery for my canon ae-1, loaded the new film, and took two shots until the frame counter read 1. the next day I advanced the film and when i pressed...
Like all AE-1's and related models, your camera is gumming up inside as the internal lubricant films are at least 25 years old and are largely dried-out.
The fix is to get the camera to a repair specialist for a CLA service (Clean, Lubricate, Adjust). As a one-off extra cost also get the foam light seals and foam mirror buffer replaced as they'll either be absent by now or will still be turning to a sticky goo. Modern foam is is different material and is will not decay like the old stuff.
A CLA and foam replacement definitely costs more than the residual value of the camera, but they're solidly built and have plenty of cheap high quality lenses so can still achieve results which compare well to even the best modern pro dSLR's. Get the work done and your camera will probably last until 35mm film ceases to be available. Your camera will also withstand conditions which you'd never dare risk a dSLR in.
Jun 27, 2011 | Canon EOS-AE-1 35mm SLR Camera
White streaks on photos
Light leak, definately a light leak. You need to change or add foam around the chamber to prevent any light from entering.
Jun 15, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 Dark Pictures
You my friend, need a user guide. Try this link:
http://www.lensinc.net/manuals/CanonAE-1user.pdf
Pages 23-26 will cover basic shooting. There is much to learn in the world of photography, so read the manual well and practice.
Dec 30, 2008 | Canon EOS-AE-1 35mm SLR Camera
Blank Film Developing
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shutter Speed
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
Sep 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Light meter problem and blank developed film
I'm afraid you have a somewhat serious problem. There is a tungsten cable that runs from the speed dial to the rewind side if the camera. This cable sets the brushes for the electrical contacts the are under the rewind assembly. Adjusting speeds or ASA changes the position of the contacts.
It is very likely that the cable has broken and needs replaced. Canon no longer supports these nor do they have parts
Feb 10, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon A1- Just stopped working
Get a dummy film and put it in the camera , make shure that the film is fully loaded on to the take up spool and test it all the way through, It sounds like the film is coming off the take up spool. I have repaired a lot of these A1's and they don't suffer from this problem. yours Tim 01689 818009..
Oct 03, 2007 | Canon EOS-AE-1 35mm SLR Camera
AE-1 Didn't Take Pics
Possibly the film did not go through the camera. If it did, the problem may be the 2nd(or closing)curtain magnet on the bottom of the camera. When the magnet is working the closing curtain of the shutter is held back 1 to 1000 miliseconds-depending on the shutter speed selected by you. 1ms=1/1000 sec. 1000ms=1 sec. You can tell by 1. removing the lens 2.setting the shutter speed to the "B" setting 3. opening the film door and looking through the camera 4. releasing or firing the camera and keeping pressure on the release button. If the magnet is working, the shutter will stay open as long as the release button is kept pressed down. The closing curtain will close as soon as the release button is released. When the magnet fails, both curtains travel across the film plane together and no exposure is made. Sometimes there is corrosion on the magnet where the wires connect. Sometimes there is some foreign substance or object that interferes with the face of the metal unit that attaches to the magnet when the camera is wound. Sometimes the magnet just fails and needs to be replaced. If the magnet checks out OK the problem may be in the circuits that control the release of the magnet. If this is the problem, the camera needs to be looked at by a competent repair shop. Just so you know, new parts are getting hard to come by, but there are tons of used cameras around that parts can taken from. Hope this helps.
Jun 24, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
498 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
