Question about Sharp Televison & Video
My son got some of the screen wet with frebreeze now i have a stripe going down the picture..can you fix that
  • 644 Answers
There may be still some moisture in the lcd, best way to dry it would be a hair dryer, go around the plastic of the screen not to close for a good few minutes whilst the tv is off then wait about 15 minutes before turning the set back on, this should solve the problem, if not the moisture may have shorted out some of the componants, best way is to leave the tv unplugged for 24 hours and then try again.
Just abit of advice for future reference. If an electrical item gets wet whilst off, the worst thing to do is turn the item on, leave it for about 24 hours and dry it up as much as you can, then turn it back on and it should work fine. hope this helps and good luck
Posted on Aug 20, 2010
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
HORIZONTAL STRIPES ON PICTURE
Hi!
Turn on the camera
Pull the lens at maximum zoom
Turn off the flash!!!!!!!!!!!!!!!!!!!!!
Shoot the picture - look into the lens.
If no motion picture shutters in the lens:
1. Faulty flex cable shutter
2. Faulty valve solenoids
etc.
Requires repair of the shutter assembly in the lens
If you saw the shutter and blurry pictures as paint - matrix defective - Replace the camera matrix.
Dec 08, 2013 | FUJIFILM Finepix S2100HD Digital Camera
After being in a suitcase in the hold of a plane my camera has a white screen. I t does still take pictures but you cant see them on the viewer.
this a problem fro LCD screen or associate circuit control SYSCON., you must replace and fix it. you have 2 options a) do it yourself or b) go to the repair shop for fix it.
God bless you
Jul 21, 2012 | Cameras
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
EnV front screen has a black stripe
Its manufacturing fault which can be caused at any time while using or if it get hurts .. you can calaim its warranty or take it to near by mobile shop to get it fix .. they might change screen or the serial wire of screen
Jun 25, 2009 | LG enV VX9900 Cellular Phone
Screen got wet and picture is dark
Sorry to say, he ruined it. No way to fix. Live and learn.
Apr 26, 2009 | Audiovox D1917
Kodak EasyShare Z730 is stuck on date/time screen
I have a problem with my mouse too. If you get an answer let me know. I called tech no help. Basically told me to get a new one.
Apr 03, 2009 | Kodak EasyShare Z730 Digital Camera
DS Lite top screen has gone grey with vertical stripes down it.
It is a problem with the flatcable of the upper TFT screen or the TFT itself. Only solution is treplacement of the TFT screen (flatcable is not separate replaceble). Because you say it is not even one year old, you still have warranty. Send it to Nintendo for repair!
John
Nov 30, 2008 | Nintendo DS Lite Console
Water behind screen
Did you just sell your TV? Because if you did, I'm probably the one who just bought it. Paid $200. Anyways, if not, I did fix it. I dismantled the TV, starting with the bottom. Pull off the speaker cover then unscrew everything on the bottom in order to loosen the top screen portion. Unscrew the top screen and pull it off slowly, disconnecting the one wire that connects it to the rest of the TV. Once the screen is off, you can seperate from the frame it by unscrewing it. I then cleaned both screens (there are two layers) with distilled water and a microfiber cloth. You might be able to use other cleaning methods but I recommend plenty of water and then a non abrasive cloth. Make sure it's clean and dry before putting it back up. Picture is like new and I love it!
Jan 20, 2008 | Toshiba 51H84 51" Rear Projection...
NO PICTURE
there is a broken conductor strip or broken solder joint on the circuit board near the power input jack. do this: 1.) disconnect tv and open panel to expose circuit board. 2.) using a flashlight and magnifying glass, look carefully for this broken solder strip or solder joint. Flex board slightly if necessary to aid in finding the break. 3.) repair it using solder iron and flux solder and scratch copper conductor slightly to aid in "wetting" the solder fix.
Jun 09, 2007 | Daewoo DTQ-26S1FC 25" TV
Televison & Video Logo
143 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
