Changed from direct tv to antenna. upone doing that my panasonic plasma tv gets great reception, but on a select channels we get part picture and a black line about 6 inches and anothe part of the picture. How do I get a full screen picture?
  • 4,234 Answers
This may be a form of closed captioning. Look within the menues and make sure that closed captioning is turned off. There are some channels that send a "blank" CC rather than none at all for some programs where the actual CC is not available. If that fails to resolve the problem please try to diagram here where the black portion is located and its size.
Thanks,
Dan
Posted on Aug 20, 2010
Connected antenna but no reception. cant get tv to auto program channels. like there was no reciever. do not have original remote. spent $70 for antenna
Channel scanning probably was selected using the original remote. All remotes do not have equal capabilities.
Sep 19, 2016 | Televison & Video
Our Panasonic Viera TC-32LX700 displays "Channel not found". We have unplugged it and gone through the initial set up all over again. It is connected to am antenna, not cable. After the display, the screen...
Try relocating the location of your antenna or changing the direction it is pointed. Once this is changed, select PROGRAM CHANNEL from the SETUP menu and set ANT IN to Antenna before selecting Auto to start the programming process.
Oct 19, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Can my Panasonic TC-P42X1 receive digital channels without an antenna connected? It sounds like a stupid question considering its a high-def TV, but I'm having troubles getting the TV to pick up...
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
Aug 21, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
My t.v. has volume issues. Volume between channels and also within one channel (while viewing) not even. Happened when connected to basic cable and now when connected to just an antenna for reception. ...
it is fixable the sound may depend upon the channels also but the antenne might not beeing catching signals properly so by changing the face of antenna u can remove this problem
Mar 31, 2011 | Panasonic TC-32LX85 LCD TV
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
One channel on LCD not clear picture help!
this is a problem with the reception in your area. It should be resolved with an adjustment of your antenna to a location of clear reception.Ask someone in the house watch the television while the antenna is being adjusted for best reception and set the antenna. If you have cable, you must contact the cable company and ask them if they have a resolution to the reception problem. Hope this helps you with your problem.
Apr 25, 2009 | Insignia LCDTV26 26 in. Television
TV antenna
Hi splhcb,
Your television is already an HDTV, meaning it is set up for receiving digital broadcasts. In this case, you should not need a separate converter box for over-the-air reception. You will need an antenna, but the type you purchase depends on things like how far you live from broadcast towers, landscapes, buildings, and where it will be located in your home. Although many antennas are being marketed as HDTV compatible, if you already own an antenna you likely can continue using it. Otherwise, it is best to speak with someone at the store who can weigh the factors in your situation to recommend the best antenna.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 28, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
