Question about Sony KP-53S25 53" Rear Projection Television
Our TV has sound but no picture. Is there a reset button? Could this be a problem with the lamp?
  • 1,476 Answers
Suzy arata,
This unit has CRTs and does not have a lamp. Most likely you have a problem in the high voltage section. This can be checked with my tip at http://www.fixya.com/support/r4916941-diagnose_repair_projection_tv_high which explains the problem although it was written with a dead set in mind. It also tells you where to get the best price on parts. There is an outside chance that you could have a video drive issue. This problem would be on the other board (not the board with the high voltage). There really isn't a way for you to troubleshoot this board. If you do not find any problems in the high voltage circuit I would replace the small signal board. Available from http://www.encompass.com.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Aug 21, 2010
Replaced lamp and i still have a yellow light and no picture
Check that your lamp fan is working. It may also be a bad ballast for the lamp.
Mar 08, 2012 | Toshiba 65HM167 65" Projection Television
There is a crckling noise when i turn the tv on and now there is no picture i hit the reset button and now there is sound but still no picture and after a short while couple mins the tv cuts off.
Your lamp has died. Refer to your manual on lamp replacement and remove the cartridge to confirm. then contact Mitsubishi for a replacement. They are the least expensive and the lamp is OEM.
Nov 21, 2010 | Mitsubishi WD-57733 57" HDTV
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
I replaced the lamp on my wd65736 mitsubishi .but
Do you get a red light on the front of the set comming on alerting you of a bad lamp? Did you place the cover back on correctly after placing the new lamp in the TV?
Nov 06, 2009 | Televison & Video
Picture wont come on
No reset button, you may have a bad lamp. Look in you owners manual and which light is flashing it will tell you if the lamp is a possibility.
Mar 01, 2009 | RCA P52926 52" Rear Projection Television
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all Sony KP-53S25 53" Rear Projection Television Questions
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
