Question about Maytag Neptune MDE6800 Electric Dryer
How do I remove the lid or front of a dryer so i can lubricate the rollers, etc.?
  • 77 Answers
Normally the entire shell minus the front comes off as one single unit. there are screws all the way around the back edges that will release the entire thing
Posted on Aug 20, 2010
Dryer makes continuos knocking while running
Hi derik
You did not mention what model dryer you have so I included the info of an older front load dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Apr 24, 2013 | Kenmore Dryers
Dryer making thumping noise, getting metal shavings too
Hi Jim
Mar 20, 2013 | Whirlpool Dryers
How do you get to the drum rollers on a maytag dryer model LDE612
Hi Rick
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication.
Thanks
Bud
Feb 21, 2013 | Dryers
How do i stop a dryer belt from squealing
Hi
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be your drum rollers are in need of lubrication or replacement
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Bud
Oct 10, 2012 | Dryers
Need to replace belt on maytag dryer model MDE3000AYW
Hi Roger Buttram
Bud
Oct 04, 2012 | Maytag Neptune MDE5500AY Electric Dryer
How do you replace drive belt on maytag gas dryer
Hi david lebron
This solution is for an electric dryer, but the gas dryer would be the same.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley and/or you have noisy drum rollers.
Bud
Oct 01, 2012 | Maytag PYG2300A Gas Dryer
Remove front from maytag neptune gas dryer model # mdg4000bww
Hi pcsankeny...
You will remove the gas dryer front the same as you will remove a electric dryer front.
Follow the directions below
Please take time to rate me thumbs up
Sep 21, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer squeaks
Hi ecurb99...
Your problem sounds like the drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Aug 20, 2011 | Amana NDE7800AY Electric Dryer
My dryer is really noisy
Hi tonybusanop...
Sounds like your drum rollers need lubricant or replacement as they will make noise when dry or worn like you describe.
I will include info on replacing the rollers on an electric dryer, they are assembled about the same as a gas dryer.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Aug 16, 2011 | GE DPSB613GDWW Gas Dryer
Squeaks for a few min then goes away. maybe a roller?
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.(Some dryer lids will tilt back)
Also remove the screws holding the lint filter in place and remove the lint filter also.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Aug 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE6800 Electric Dryer Logo
82 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
