Question about Sub-Zero 19.3 cu. ft. / 547 liter Upright Freezer 601F
2 yrs old, huge fridge w/ 2 freezer drawers on the bottom. Both drawers are warming - set at -5 but now temp is 4. What can I do?????
What brand? trying cleaning the condenser coil
Posted on Oct 22, 2010
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Kenmore fridge over pullout freezer. Freezer has snow. Model 59673502201 . Fridge runs, and shuts off apparently normally. Freezer is cold, air blowing (fan?) from behind freezer temp control. Thought...
Please : - Clean up your freezer - set the thermostat to middle - check the fan for malfunction
There are many things that cause your freezer work abnormally.
Nov 07, 2010 | Kenmore Freezers
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Sub-Zero 19.3 cu. ft. / 547 liter Upright Freezer 601F Logo
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
AJMAL KHAN
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
