Question about Fisher and Paykel Washing Machines
When I turn on my Kelvinator Pride 5.5 (smart drive) washing machine it will only partially fill (and the water pulses in sporadically rather than one even flow) after 1 minute the machine stops and the error lights show. if i start the wash half way through a cycle it tries to start but again stops after a minute. the error lighting is (from left to right)of the eight lights: third light lit green, fith light lit green, 7th light lit orange and eight light lit red. please can you help me fix this issue?
5 Suggested Answers
  • 251 Answers
SOURCE: Fisher & Paykel Pride 5.5
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Posted on Jul 12, 2011
blueextc3221
  • 15935 Answers
SOURCE: washing machine errors
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!1
Posted on Sep 15, 2010
  • 10 Answers
SOURCE: Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Posted on Dec 27, 2010
rickead1
  • 1998 Answers
SOURCE: I have a Fisher & Paykel Washing Machine (
So if you were to count from left to right then lights 3,5,7,and 8 would be on correct? If these are the correct lights lit your machine is giving you an error code the motor controller module has found that the signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
check that the out of balance switch is free to move
check that no harness is blocking the switches movement
check that the switch activates properly when activated replace if it does not
if the switch shows signs of corrosion replace the switch and the harness and fit a condensation kit
check the level of the machine and also the bias switch
check the harness is connected correctly
and finally if all seems good with the switch it states to replace the motor control module if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
Posted on Aug 15, 2011
Kelvinator 085 Smart Drive. Why won't it start?
kelvinator smart drive 085 washing Questions & Answers ...
www.fixya.com > Forum > Tags
smart drive 085 not filling with water when start button depressed Could be the magnetic latch on the lid that tells the machine when its closed you can by pass
Sep 30, 2015 | Washing Machines
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9 won't spin
There's something wrong with it. It sounds like its broken and needs to be fixed.
Nov 08, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Kelvinator Smart Drive 601. Machine does not complete full cycle. Stops at most stages and beeps. Seems to have trouble with water intake. Hoses have good water pressure when...
the magnetic switches may be warn. in hard water areas they can block up and stop working. you may need to change them or take them out and stick them in some vinaga and see if it will soffen the hard crust off the inside of them out.
Oct 06, 2013 | Fisher and Paykel Washing Machines
You need to read the error code
and tell me what lights are on
Aug 17, 2012 | Fisher Paykel Eco IWL16
I have a Frigidaire Pride Smart Drive top loader washing machine and I would like to give the bowl and inside where the powder goes in, a jolly good clean. How do I go about this? I'm worried that...
hi i have a fridgedair pride 5.5 wen i turn my washing machine on theirs know water going into the machine the water keeps going stop go stop go how can i fix the problem every thing else is fine.
May 26, 2011 | Fisher and Paykel Washing Machines
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Hi, My washing machine washes for 10minutes and then beaps until I turn it off. It is full off water and i can't drain it. It's a Smart Pride Drive 5.5. Thank you. Tara
Mine was doing that but it's not any more. I think it may have been too heavy/packed. Have you tried packing the washing in more losely and not filling it quite up to the top?
Sep 09, 2008 | Fisher and Paykel Washing Machines
Washing Machines Logo
85 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
