Question about Nokia 6120
I am not receiving notification of messages, on the screen, via the little envelope or tone on my nokia 6120? what is wrong/how can I fix this?
I had the same problem n i'm using 6120 too..
check out how many messages are in ur inbox. mine was over 2000 back then. so, just delete some messages til ur messages in ur inbox not more than 2000. then just take out the battery from the phone when it's on, then turn on ur phone again.
it works for me..
Posted on Jan 18, 2011
My nokia x5 is recieving messages but the message tone doesnt alert me and there is no message notification or icon telling me i have a message how do i fix this?
I also share the same annoying problem. Only a little icon shows I have an unread message, but no tone!!! Only a very soft "beep" sound~! So ANNOYING!!! :(
Mar 20, 2011 | Cell Phones
Envelope Notification showing one message
If you call your service provider, they should be able to clear it, provided all messages have been read and you don't have any voicemail waiting to be heard. They can send a "0" count through their switch (processor) to your device which will in turn clear your message waiting indicator.
Aug 21, 2009 | Cingular Wireless AT&T RIM BLACKBERRY BES...
Msg Received Icon
On the Personalization screen, press Home screen. On this screen, make sure that "Active" is enabled. Then press Mode settings, then Home screen applications, then Enabled applications. On that screen, you will see a list with squares some of which are ticked and others not. The ticked items appear on your active home screen. Scroll through the list and tick the Message notification box. Hope this helps!
Jul 12, 2009 | Nokia E71 Smartphone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Message icon and alert
you will need to contact your mobile provider and explain it to them and have them correct that on their network.
Sep 19, 2008 | Nokia 6120
Nokia 6120 question
This might be much to late but I am posting this because I could not find a solution on the web.
I had a similar problem after moving my sim from another phone to the new 6210. In the end it was because there was old unread SIM messages on the SIM card. I deleted them and all was fine.
To do thes go to messaging, select OPTIONS, SIM Messages. Mark all and delete.
Cheers,
Robert Mugabe (who is an arse)
Jul 05, 2008 | Nokia 6120
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan(sajwhat_2003@yahoo.com)
May 03, 2008 | Nokia 6600
6630 sms problem
It appears that you have other programs running in the background and haven't been closed. To check this keep the menu button pressed for about 2-3 seconds and the phone will show the programs running in the background. If there are more than 1 close the others that's it.
also check the date and time on your phone and update it if it isn't current.
Nov 11, 2007 | Nokia 6630 Cellular Phone
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
Nov 07, 2007 | Nokia N73 Cellular Phone
Nokia 6120 Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
