Question about Alpine CDE-9852 CD Player
There is no power to the speakers at all anymore. The only sound that you hear coming from them is a pop when the deck is turned on. All the functions still work fine. It still reads the Ipod and says it is playing. Cds show that they are playing. It seems like maybe a fuse is out inside the deck. I've also check the power IC and it is set to on. Do you know what could be causing this problem?
  • 156 Answers
SOURCE: Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
Posted on Jun 09, 2007
  • 300 Answers
SOURCE: music won't play through speakers
Please provide more detail of your system's setup and connections. Thanks!
Posted on Mar 05, 2008
SOURCE: alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Posted on Jun 19, 2008
SOURCE: no sound through speakers
check the manual to see how to turn IC on and off. Maybe the deck is set to de-activate the internal amp
Posted on Jul 13, 2008
  • 34 Answers
SOURCE: Haveing trouble hearing sound when I have my IPod connected
Have you tried turning up the ipod. the RCA AUX in is looking for 5v line level
Posted on Mar 14, 2009
My pros can ps56670 makes a popping noise when I turn it on but won't come on no picture
I just answered this for someone else; this sounds like a power control board problem. Basically something has short circuited and if you're hearing popping from the back and not the speakers it a power problem. If you're hearing it from the speakers but no picture then you need to replace your control board.
Jun 07, 2015 | Televison & Video
I have a 2005 Honda Accord. The radio has been hot to touch since i had gotten the car. Iv taken it back to Honda in the beginning but thy kept saying they don't understand and not getting the same...
Could be a bad wiring job, blown speaker or pinched wire.
1st step would be to disconnect all speakers - the deck should no longer get hot. If it does, you have a bad deck.
2nd step - hook one speaker up at a time until it gets hot. - Then you know what speaker/wire is the problem. Fix that.
Feb 04, 2011 | Car Audio & Video
Im having kenwood home stereo system model no xd-v818 high volume about 80 the sound starts to distoriate and the voice is not clear..i want to kno wether the stereo deck is not able to provide...
Well, here is the situation as I understand it. Here is also some theory to help you out.
Your Receiver or Amplifier has a "scale" showing relative volume. Distortion always increases in speakers and amplifiers when you turn them up. If the sound is getting extremely distorted, the Receiver is attempting to operate above it's maximum output. The scale is an average, but because music recordings are often mastered at different levels, "80" may be too much. When an amplifier section of a receiver is over driven, the distortion (which you observed) will damage or burn out your speakers. Most likely the tweeter (high frequency speaker)
If you back off the volume, or turn down the output of the deck until the sound becomes clear, then that level, IS FULL VOLUME. Based on what you are saying to me, I don't think anything needs service.
There is one other very important thing I should mention to you
. When people use high powered equipment and initially turn up the sound. After a short time, the mind turns it down. What next happens is the reason professional musicians and sound engineers often have permanent hearing loss after a relatively short time.
What happens is that the listener and often the engineer running the sound board at a concert thinks the sound is not loud enough (when the audience is happy with the level) and turns it up. After turning it up, his mind (and the audiences') turns it down and then he thinks it not loud and then again turns it up. And up. And up. The only reason I'm not deaf is that I discovered this when I was building sound systems as a kid. I also studied about it. So please be careful when you play things loud. Permanent hearing loss starts to occur at the very high frequencies and rolls down from there over a period of time. Hearing loss can start to occur in just a few hours.
at 110 decibels. It doesn't come back. If you understand this, you'll keep your hearing.
I hope this helps,
Best Regards,
Jan 22, 2011 | Audio Players & Recorders
"pop" in speaker when turned up
more likely your deck is just running out of power. another cause is the speaker leads could be hitting the metal of the car with the bass, check for clearance.
May 19, 2010 | Alpine SPS-609 Car Subwoofer
Radio turns on but no sound 1999 dodge intrepid
If all your connections are made correctly its is possible that one or more of the speakers have shorted out. Some radios will shut down the internal amplifier if it sees a problem.
Best way to check is to remove the radio and access the speaker leads. One speaker at a time take a battery like a 9v and put the positive and negative leads on the terminals of the battery. If the speaker is connected correctly than you should hear the speaker pop. Don't worry it will not damage the speaker. If you do not hear the speaker pop than there is issue between the wire leads and the speaker. Maybe the speaker is blown or just disconnected in the door.
If all the speakers DO pop when you applied the voltage than it is an issue with the deck.
Hope this helps.
Please Vote & Rate
Mar 08, 2010 | Pioneer DEH-P4700MP CD Player
Popping and Humming noise from my audio system?
Ground Loop Isolators are nice, but if you want truly crystal clear sound, you will need to run a common ground. All electronics will need to be run close to the amp, as more than about 3 feet of ground wire from the amp can cause sound issues. When I ran my common ground, I connected my radio and satellite together, and ran one sigle ground wire to the backseat of my car, where the amp grounds are located. This will optimize the clarity of the sound coming through the speakers. For the popping sound in the speakers when the car is powered on or off, you need to see if the radio itself has a wire to power the remote connection on the amp. Most of the time, they will, and this is the wire you will use to turn on the amp itself, as it delays each item powering on and reduces the chance of popping in the speakers. DO NOT run the remote wire from the amp to the accessory wire of the radio, as this will cause the popping sound you are hearing. If the radio does not have an Amp Turn-on wire, then you may need to improvise by using an accessory wire in another location, but even this is may cause popping as well. The pop comes from multiple things turning on at once, so the Amp Turn-on wire delays the amps for just a moment, preventing the pops.
Oct 05, 2009 | Pioneer DEH-P6400 CD Player
I get a pop from the sub when the power comes on.
This is caused because the stereo you have put in, is a high power output, or higher than the factory and puts that extra power into the factory amp systems causing the amp to surge the power to the speaker resulting in the pop sound,most newer cars use a stereo system without an internal amp so as to reduce heat and a external amp in usually under a seat or dash and a high power stereo boost the output of the amp.
Sep 27, 2009 | Car Audio & Video
No audio output
Were you playing it very loudly when it died?
The manual is here for reference...',600,560,10,10,'Manuals'
It discusses troubleshooting this problem on page 50.
When you turn the receiver ON does you hear a light click in about 5 seconds? That would be the protection circuitry turning OFF to allow the amplifiers to function. The delay is to allow the circuitry to stabilize before it sends any output to the speakers. If you don't hear a click the unit is Protecting the speakers due to malfunction somewhere.
If no click and no apparent messages try turning the speakers OFF using the Speakers button directly below the Power button (1/0). This will eliminate or point to external shorts as the cause.
Does the unit click after 5 seconds of Power ON with the speakers OFF? Isolate your shorted speaker or wire problem.
Still no sound at the speakers when you turn them ON?
We need to establish if there is any programming flowing through the receiver.
A quick basic check would be to tune an FM station, if you have a tape deck attached, place it in Record or Record/Pause mode so it can display the input signal levels. You should see the record meters fluctuating with the level of the program selected. If you don’t have a tape deck, run an RCA cable pair from the audio output for a tape deck to an analog audio input on your TV. Select that input on the TV and you should hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason.
If there is no audio flowing through the receiver the problem could be a switch in the wrong position, source not selected, muting on or a multitude of other things.
Let me know how this turns out.
Apr 03, 2009 | Sony STR-DE695 Receiver
I have HP Multimedia Speakers. No sound comes from speakers. computer says Realtek digital output...Realtek high definition audio working.
If your speakers are powered speakers i.e. they plug into a wall outlet\has a red power LED etc...then unplug the input wire from your computer. Turn the volume all the way up on the speakers. This'll sound silly but it works. Lick the tip of your finger and tap the input wire tip with your wet finger. You will hear a "Pop" come from the speakers every time you touch the input wire to the speakers. This tells you the speakers are working and your computer is to blame. Good luck!!
Oct 02, 2008 | Audio Players & Recorders
Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Jul 08, 2007 | Panasonic CQ-C8803U CD Player
Alpine CDE-9852 CD Player Logo
50 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
