Question about Kodak Easyshare V1233 12.1MP Digital Camera with 3x Optical Zoom
My camera lens dont open why??? - Kodak Easyshare V1233 12.1MP Digital Camera with 3x Optical Zoom
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 20, 2010
Digital Camera Samsung S760 lens open and close not crooked. beeps twice
My Samsung Camera Lens is Dont Open i dont Know Why .!
i can describe that Thing ..> When im Going to activate The DigitaL camera in Work The Lens is Open in half no at All and do one Noiz like dont have enought Battery But i Charge the battery 5 days to Proveee that in Camera but this thing Didn't Happend
Tell mee why and what can i Do to haveee again My camera :D and to do Photos
Oct 14, 2010 | Samsung S760 Digital Camera
When i switch my camera on it bleeps 3 times and switches off again. i have replaced the battery but to no avail. any ideas?.
are you shure that you dont have dropped on the camera....
why any time a pressure on the camera can broken the lens dispositive..and the if you turn on the camera she dont can open the lens and turn of.
but to first you must are shure that your batteries are early charged.. that you dont have a foul batteries,,,you think that is conpletly charged but the batteries is not. if the batterie is caharged and the camera blinks and dont turn on ...i am sorry but i think this is a lens or motherboard problem.
Jul 10, 2010 | Samsung L210 Digital Camera
Lens error
if you have the expertise, open up the camera, and check that all the ribbons are secured by removing them and putting them back. Be very careful though, as i got a few shocks from the motherboard, even after removing the batteries!
i had this exact same problem, turns out the ribbon for the lens had come loose, after too many falls.
however if you dont have the expertise to open it, find someone who does :)
Dec 27, 2009 | Nikon Coolpix L1 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 07, 2009 | Sanyo VPC-E760 Digital Camera
Lens error on SD1000 Canon but opened lens and made it worse!
Lens error means that either it was dropped on the lens or the lens just failed. You could be looking at a $90-$120 repair
Dec 31, 2008 | Canon PowerShot SD1000 Digital Camera
Stuck camera lens
i dont think you can do anything you just have to reffer to a proffessional because there are some gears that maybe damaged
Nov 01, 2008 | Nikon COOLPIX P5000 Digital Camera
Coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 26, 2008 | Nikon Coolpix L11 Digital Camera
Lens error 14 lens error 22
sometimes my lens does not open up and i dont understand why and plus, i always get the lens 14 and lens 22 error. i need help with it, this camera course me a lot of money.
Apr 24, 2008 | Cameras
Camera lens cover is sticky
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Kodak Easyshare V1233 12.1MP Digital Camera with 3x Optical Zoom Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
