Question about Bose Around-Ear Headphones - Silver
Left chanel on headphones has stopped working
  • mokups Aug 21, 2010
    ok. I have checked the wires and all seems to be ok. I removed the plastic section inside containing the speaker and noticed that there is a clear plastic membrane over the magnet in the centre of the ear piece. That plastic seems to have come away from the walls of the plastic frame work. Would that cause the unit not to function?
    Thanks for that. I have checked the wires and all is ok. I did find out however that the plastic membrane that covers the magnet in the centre of the earpiece has come away from the edges. I'm assuming that this might be the problem and that the headphones are non repairable. Would I be right?
    Mike
  • 857 Answers
It is a disconnection in the wiring thats the reason behind this problem.
Posted on Aug 22, 2010
  • Jayant Jha Aug 22, 2010
    what you mentioned is one of the possibilities for the problem.
    President:
  • 1,194 Answers
Test your head phone with other device like MP3 player, Walkman, or mobile phone and check whether left channel is working or not, If left channel of headphone working with other device then your headphone is alright.
If left channel of headphone is not working with other device then definitely a wiring fault, either the plug is not connecting to the port well or at some point the left wire is broken, probably where it meets the left earphone. Try jiggling it around near the earphone while playing music, and see if you can get it to work, otherwise there is not much to do other than getting a new headphone.
Thanks for using Fixya,
Good luck and have a nice day
Posted on Aug 21, 2010
  • 12,061 Answers
Hi, well usually whenever this happens, in my shop, it is the cord, they break internally, usually, by the Plug, or by the entry point into the headset. Occasionally it may fail in the length. You maybe able to feel where the break is, by running your fingers along the cable, when you come to the area of damage, it will feel different, sort of easier to bend.
If you are handy with a soldering iron, then you could no doubt resolder on a suitable cable, you should be able to get one from say radio Shack, or similar.
if you know any local TV repair people, I am sure they would have NO problem redoing a new cable for little cost.
Otherwise the only other option would be a new set?
Posted on Aug 20, 2010
No enough sound fro right chanel of a headphone jack
check your audio manager and adjust your left right channels
Sep 01, 2013 | Acer Extensa 5630-6806 Notebook
My left headphone stopped working after a year or so. How can i fix this?
The copper wires inside the cable have broken. Since you don't know where the break occurred all you can do is to open the left headphone, remove the speaker, cut a piece of the cord and resolder it to the speaker. Test it, if it's fixed just put the headphone back together. If not, cut another piece. If you must cut more than a third of the cable to get it working then it's dead, just buy a new pair.
Jun 30, 2010 | Sony Bud Style Headphones
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
Hello, headphone jack is loose, i have to hold the jack and press ir against an angle to make both chanels work. walter
Hi Walter,
If the headphone jack is loose you can try to use the USB headset (If there is one) or Bluetooth.
If you wanna fix the headphone jack yourself you can find a very good step by step guide here.
The repair service will take about anything from 40$-60$ to repair it.
Good Luck!
GetAFix99
Nov 17, 2009 | SanDisk Sansa E280 MP3 Player
Numark cue mixing
to change headphone track, use the cue slider which is located on the right of the control panel above the right chanel treble control and below the cue gain control. chanel 1 or 2 can be selected or in the middle for a mix of both tracks just like the cross fader.
Feb 24, 2009 | Nu Mark Numark Dxm06 DJ Mixer With 12...
JVC dual channel bridgeble Amp
Most repair shops offer a warranty. If you've recently had it repaired, return it to the shop to have them check it out. If you continue playing it as it is, more damage may occur and the additional damage isn't likely to be covered by the warranty.
Jul 01, 2008 | JVC KS-AX4750 Car Audio Amplifier
Left Headphone not working
well maybe because, you to cheap to by good headphones
Mar 04, 2008 | Sony MDR-G42LP Consumer Headphones
Button/Jack
Replace the player - there is no repair for this
Jul 02, 2007 | iLO (2 GB) MP3 Player
Bose Around-Ear Headphones - Silver Logo
637 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
