I have a split system trane I16i 5 ton making a loud humming noise when it is in the first stage once it kicks into 2 stage it sounds ok
  • 107 Answers
Trane has issues with loudness of their 2 stage system. Not saying its normal just saying its common. If you notice cooling ok in both stages then it can be narrowed down to refrigeration flow is noisy or a solenoid valve is loud.
Posted on Aug 21, 2010
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
3 ton heat pump with piston in air handler. After unit shuts down it makes loud fluid flow noise for about 2 minutes
adding a tvx will not help. the sound you here is the pressure equalizing and that has got to happen for the compressor to start again the next time. A tvx will give you a higher efficiency because it can adjust to changing temperature conditions. Only way i know to quiet the noise is to try to insulate the lines better.
Sep 14, 2014 | Goodman GSH130301 Heat Pump, 3 Ton, 13...
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
Garbage disposle makes a humming noise when turned on. InSinkErator Badger 5, 1/2 HP Garbage Disposal
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
May 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
Trane XL19i 8? ton heat pump not heating very well
Your second stage heat check the dip switches on the board and the wires to the proper two stage heat t-stat.
Feb 06, 2009 | Omega Trane Furnace Draft Inducer Blower...
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
