Question about Panasonic SC-DM3 System
How do i connect my sc-dm3 system to the tv so we have sound for ps3 and sky hd
    Problem Solver:
  • 4 Answers
Using red yellow cable connected to aux on home dm3 connect other end to audio out on tv
Posted on Oct 03, 2013
SOURCE: ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Posted on Sep 03, 2008
  • 4 Answers
SOURCE: how to get surround sound workin with ps3 and tv
you have to select the dolby surround button from the remote to get the sound
Posted on Dec 25, 2008
Just_Bobz
  • 448 Answers
SOURCE: how do i connect a panasonic theater system to asylvania tv
For best results either use an s-video connector and RCA Red/White for the audio. If no s-video available, use comp which means composite (Red,Blue, Green) so the truest color can go from one unit to the other. On the back of the theatre system, plug everything into "output", on the panasonic, input.
Posted on Dec 31, 2008
  • 21 Answers
SOURCE: No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Posted on Sep 14, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do I connect my 42" Vizio HD TV to my
You could just source the audio from whatever external source you're watching (BD,DVD, Cable, SAT) directly and digitally to the Panasonic. The TV doesn't need to be an active player in the audio chain. Some have NO audio capabilities at all yet we manage. Treat it as the end of the chain, not a link.
Posted on Dec 26, 2010
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
Currently i have a sky hd box connected to my tv by a hdmi cable i want to connect my ipod into the sky box so i can play music videos ipod and sky box are close together and i don't want to connect ipod...
This isn't possible, the USB on the front of the Sky HD box is not active. I don't have any information on whether it will be in the future.
Your only option is to connect the iPod via TV or if you have a surround sound amp
May 21, 2010 | LG LH-D6230 System
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Help how to best connect sky hd and PS3 to a Jamo
you will have to use a component cable or optical lead from your ps3 to the jamo and sky hd to be connected via scart.
for best image,buy an HDMI CONNECTORS switch that will allow you to run many HDMI TO IT and from the switch you only need one to the tv so the jamo still output to the tv.
remember that you will have to get an automatic one so that it can select when you are using each element.
Mar 04, 2009 | Jamo DMR 60 DVD Player/Receiver
Dec 10, 2008 | Panasonic SC-HT75 System
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Panasonic SC-DM3 System Logo
91 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
