Hi Our Miel W830 front loader is not spinning for the wash cycle and the drain/spin cycle. Water fills up and drains the machine itself does not spin at all.
  • Mitieli Bovoro Aug 21, 2010
    Sorry for the late response Had to go and vote - National Elections in Australia today. Have lifted the top. Seen a black tube connected to the drum but no switch attached to it. Just to explain problem again. When we turn machine on to "quick wash" the "on" light comes on then water starts to fill up. "Pre-wash" light goes on then "Main Wash" goes on. The light for Rinse and rinse hold comes on while the main wash is on and flickers.
    When we change the selection button from Quick wash to Drain the water starts to empty out. Even when we change the selector button to "Spin" the drum does not spin at all.
    In all the above the drum never spins at all. We can hear and see the water filling up and emptying but there is no spinning of the drum to indicate its in washing or spinning mode.
    Thanks
    Miti
  • Washing Mach... Master
  • 19,396 Answers
Hi.
If washer starts filling, then suddenly drains all water and quits, you usually fix the problem replacing the inlet valve. First ensure that there is enough pressure at inlet , and that inlet hose is not kinked or blocked.
If the inlet valve is not the problem, test pressure switch and timer board. Problem is usually the inlet solenoid valve.
If the machine fills completely and get stuck before spinning, with cycle hanging there for a while, then replace the pressure switch.
Posted on Aug 21, 2010
  • 17,099 Answers
There is a device that tells the machine when it is full and therefore when to start the agitation. You need to lift the top and look for a tube that connects to the drum and has a switch attached to it. The fix is to remove the switch and clean it and the tube out.
Posted on Aug 20, 2010
I have a Frigidaire washer 2003 model no. gitr 1670 aso front loader that will not wash or spin. Everything else works like fill with water and water drains.
Hi friend, thanks for your post!
I see that your Frigidaire washer is not washing or spinning but everything else is working properly. I would advise you to check over the drain hose, make sure it is not restricted or too far down the drain pipe. If that checks out it could be a possible problem with your motor or control panel. One of those components could need to be replaced and for proper replacement I would recommend assistance from a technician to have a proper diagnosis completed. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire GLTF1670A Front Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Apr 21, 2011 | GE Washing Machines
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
heatman101
Apr 21, 2011 | Roper Washing Machines
Asko front loader, fill with water but won't wash, drains water OK
Hi, Have you removed the back panel to insure the belt is on ? What about the spin cycle, will it spin ? (That will also tell you the belt is good by the way) I'll watch for your reply. Regards, Macmarkus :)
Dec 09, 2010 | Asko W600
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't drain and spin. Cycle completes and all the lights on far right flash. Door won't open. Bottom of washer is filled with water. Tried putting it on drain and spin cycle. Still won't drain. Beeps...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Frigidaire Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Washing Machines Logo
Top Washing Machines Experts
