Question about Dual XD-7500 CD Player
How do I connect to my 2002 durango. The jack is different and the wire colours are also different.need assistance asap
    President:
  • 676 Answers
It will be much easier if you go to your local auto parts or stereo dealer and ask them for an installion harness. This will make your headache go away and much easier to do. Good Luck.
Posted on Aug 20, 2010
Multiple codes on 2002 dodge durango
This many codes sounds like a wiring issue. You need to inspect all the wiring. If you have rabbits in your area, they eat wires. If not then it is likely to be a corroded or loose ground. You need to get a wiring diagram etc.
Feb 25, 2014 | 2002 Dodge Durango
2002 Durango won't start change fuel pump, cramnkshaft sensor,
"No Bus" means something happened between the body computer and the engine computer. They are not connected to each other.
Usually a fuse, one of the computers, or the wiring harness in between.
Apr 07, 2013 | 2002 Dodge Durango
How to fix a 2002 dodge durango with p0051,p0136,p0031 codes
All 3 of these Codes have to do with the O2 devices. Some are saying the heating elements are returning low signals. These elements are built inside the O2 sensors and are designed to make your vehicle get out of "rich" mode faster.
Bank2 sensor1, Bank1 sensor1, Bank1 sensor2. Check your connections and the wiring leading to these parts.
You may need to replace these O2 sensors if the wires are good.
Sep 15, 2012 | 2002 Dodge Durango
Humming sound cumin from my creative inspire 4.1 woofer
Make sure that you've fully pushed in the jack to the sound card.....maybe you've not connected the jack into the correct socket on your soundcard as there are usually 3 identical sockets...but only 1 is the correct one. Sometimes colour-coded green. Try it in each one in turn. If you have headphones, try plugging them in as you will hear sound in them when you've got the correct socket!
Apr 27, 2012 | Creative Labs Audio Players & Recorders
Fault commjg up bank 1@2 mixture too lean
most likely cause is the oxygen sensors ,and to check this out you will need a automotive test meter ,the two wires the same colour should read 12v across them and the other two wires should show different voltages with engine speed ,then remove the connection plug and check for continuety across the two wires the same colour as this is the heater circuit
Sep 07, 2011 | 2002 Jaguar X-Type
The door lock wiring loom is different colour wire on a 99 to a 2002 model. i need to know which wire connect to which?
if the multiplug is the same just reconnect it ,colour of wires not important i wouldnt have thought ,if not sure use a multi meter to determine the feeds ,at the worst you can only blow a fuse by playing around with it
Mar 07, 2011 | Peugeot 405 Cars & Trucks
How do you hook up a amp with a factory radio.. a 2002 impala
1- you need to provide a fused power wire from battery to amp
2- provide a ground wire from amp to car body or frame (be sure to clean off paint if connected to body)
3- connect your remote wire to your fuse box (16 to 22 gauge wire will be fine)
4- connect a line output converter which will allow you to use rca jacks (one side connects to the speaker wire in your car and the other to your rca jacks)
5- finish by connecting your speaker wires and rca jacks
if helpful please rate 4 thumbs up.
Jan 15, 2011 | 2002 Chevrolet Impala
Code p0300
Hello
Here is a list of what i have found with your problom
Let me know if you need assistance in checking anything out
  1. Spark plugs
  2. Spark plug wires
  3. Ignition coil
  4. Fuel injector
  5. Wiring to fuel injector
  6. Timing Belt
  7. Vacuum leak or stuck open EGR
  8. Contaminated fuel or bad fuel pump
  9. Weak compression
  10. Blown head gasket
Jul 14, 2010 | 2001 Dodge Durango
Jack plug wireing
This is an area a technician should repair,faults in other areas of your computer may occur if not carried out correctly,
Warrantees are definately void if you attempt this type of repair and kill your motherboard (costly replacements)without prior experience I would give it to the technicians,
Solder is solder but comon sense must also prevail first.
Technician repair $100nzd replace mother board $400nzd(approx)check out some prices yourself,you may be pleasantly supprised.
I am an Electrician and have serviced many laptops over the years,,
Your question which one is the data line?
None of them are data lines at all,they are power not data.
>>>>Power Kills,Instantly,Anyone & Without prejudice,
>>>>Please Be Extremely careful.
the colour codes you explain describe the voltage supply colours which are governed by standards worldwide,different colours for different countries.
In New Zealand the wiring codes for these colours are specific,Brown = Live , Blue = Neautral , Bare = Ground/Earth
Tools required,
Multimeter,Small screw driver, solder iron,solder
Assuming you dismantled this unit,
the same process of connection will apply but in reverse ,
put the connections back the way you found them,
just taking extra special care not to short any connections thru excess solder,testing should be with a multimeter,
condinuity first then voltage,
output voltage of the charger is printed on base or body
you can check output before connection to jack and input of new soldered part for consistancy of circuitry,
Leave on charge if alls well and enjoy.
Jul 13, 2008 | Dell Latitude D600 Notebook
Wire codes
Usually power is the wire that is solid colour. The ground or NEG- wire has a trace on it
Feb 18, 2008 | Car Audio & Video
Dual XD-7500 CD Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
