Question about Jl Audio Slash v2 500/1v2 Car Audio Amplifier
I believe the RCA inputs on my amp may be faulty. how do i go about proving this. and is it something i can fix or test to find the absolute problem. everthing works EXCEPT audio. is it the inputs or internals of the inputs becuase iv noticed they dont hold the cables tight. they kinda fall out
3 Suggested Answers
  • 97 Answers
SOURCE: i am not sure where
is there a high input and a low input
Posted on Nov 08, 2008
  • 58 Answers
SOURCE: have a JL audio slash 500 that isnt putting out
Yes it possible that the inputs have been damaged on the circuit board of the amp. If the amp has hi level inputs you could try running a speaker wire input to it and see if it works. You might try another pair of rca cables to.
Posted on Aug 20, 2010
What are DTC P0107 and P0108 for this vehicle?
Use your computer Google or whatever & type:
OBD PO107
Just learn how OBD2 Systems work, because codes
have nothing to do with installing parts
You have to know how the vehicles systems & components
work & how to test them
You only replace parts when you find a problem & a part fails
a test or data is not correct
You need knowledge & professional scan tool to even work
on any vehicle since 1981
Jun 11, 2014 | 2004 Nissan Titan
DTC Code P0107
P0107 -- CONTINUOUS
Continuous diagnostic trouble code P0107 indicated barometric pressure out of range low was detected during normal operation.
Possible cause
- faulty internal BARO sensor (PCM)
Perform KOEO On-Demand Self Test.
Is P0107 present?
Yes, REPLACE PCM. CLEAR DTC and RETEST.
No, P0107 is intermittent fault. CLEAR DTC. If DTC reappears, REPLACE PCM.
If you keep getting it, a new PCM is the only fix.
Sep 21, 2011 | 2001 Ford F350 Super Duty SuperCab
I am trying to get the rear speakers for my clarion stereo to work. I found where they were wired to an amp at one point. I put in a new amp and the input is through the speaker wires, not RCA input. The...
Are you using the factory speaker wires or did you run brand new ones ?
That could make a big difference
this may sound dumb but....
is there an input switch on the amp?
And is the polarity correct on the input wires?
Jun 02, 2011 | Clarion Car Audio & Video
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
My amp use to work fine now it turns on then turns off...
Try disconnecting the RCA inputs and the speakers.
If it still turns on then off... Amplfier is faulty. Send to reputable repairer to be fixed. If not then check that you speakers are not faulty by connecting them back 1 at a time.... checking the amp after connecting each speaker...
Oct 28, 2009 | Car Audio & Video
Power acoustiks amp wont get off protection mode? how do i reset it? please help me i tried everything.
Hello nfox1987,
First you need to determine if the amp is defective or if something else is causing it to go into protection, most often a short in the sub or amp wiring.
Disconnect the sub(s) from the speaker output terminals and the RCA inputs from the head unit, and test if the amp powers up OK. If it does, the problem is in the sub(s) wiring or voice coils, or in the RCA inputs to the amp. Reconnect each one-at-a-time to determine exactly where the short is and repair or replace the defective wiring or unit. If it doesn't power up with the inputs and sub(s) disconnected, the amp itself is most likely defective.
Hope this helps.
Jul 15, 2009 | Sony XM-475GSX Car Audio Amplifier
Kicker IX404 Rear RCA Input not working
possible out from radio is bad or rear input on amp put front rca in the rea and see wht happen if you get sound use two y splitter and make connection to amp
Apr 04, 2009 | Kicker IX404 Car Audio Amplifier
Power on green light is on but no sound when speakers are hooked up
Light is on so suggests power, earth and remote turn on cable all ok. Now you just need to test the RCA signal and the AMP output. I take it you have used low level RCA as the input from the head unit? (two cables usually red n white although can somtimes be other colours) best way is with substitute amp n speakers etc although can be done with osciliscope or headphones. Once it is established the RCA signal is fine then you can check the speakers from the amp. disconnect them at the amp and put each of the two wires briefly to a battery, any battery will do e.g. 9v PP9 or 1.5v AA etc you should hear a pop from each speaker as you do it. that proves the speakers and wiring to them.
If there was no signal from the RCA the cables may be bad - requires testing from head unit to amp
failing that the RCA output may be reduced or turned off via a menu in the head unit
Or the RCA output from the unit may be knackered.
Sorry its a bit long hope it helps
Luda
Jul 04, 2008 | Jl Audio Car Audio & Video
Sharp sd nx10_out signal trouble
Try all of the spaekers on the channel you know works. If all are fine, swap the speaker lines to test them. Is the input a DVD player on RCA cables? A bad signal cable from a component can be a source for problem. Connect the speakers directly to the amp(if possible) bypassing the sub box. If all works without the box, suspect bad crossover or in the self-powered boxes a bad amp.
Jun 22, 2007 | Sharp SD-NX10 CD Shelf System
Jl Audio Slash v2 500/1v2 Car Audio Amplifier Logo
104 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
