Question about Refrigerators
Hello,i have a RB195BSBB Samsung bottom freezer fridge.The freezer isnt freezing and the fridge is filled with ice at the vents.The display shows the freezer at 28 but everything in the freezer is defrosted.I was told it was main control board,any ideas?thanks
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
Sea Breeze
  • 4655 Answers
SOURCE: hoypoint ffa9op.defrosted
Has the problem been slowly developing? Is fan inside freezer compartment running? Can you hear fan and compressor running below or behind refrigerator? Is there a collection of dust under and below refrigerator?
Below is a link with more Q&A Click on link and if you need me to assist you are welcome to let me know, Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
  • 163 Answers
SOURCE: Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Posted on Mar 09, 2009
lsteward68
  • 331 Answers
SOURCE: Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
Posted on May 26, 2009
  • 111 Answers
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
Posted on Jun 17, 2009
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
We have a Kenmore top freezer (no ice maker) refridgerator less than a year old. The frige part is warm while the freezer is frozen. Turns out the vents on the top of the fridge were clogged w ice. We...
Very likely the vents are freezing due to the defrost drain is blocked so instead of the water from the defrost draining into the pan on the bottom as its supposed to its pooling in the freezer and freezing over the air vents.
This tip i wrote will help ya to clear the drain. http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Kenmore Refrigerators
Samsung Model SR 21 NME. The freezer is on the top, this freezers fine, but the fridge isnt even cool. We have taken the back off the freeze to do a complete defrost. The fan works fine. But the ttemp dial...
Inside the fridge compartment, at the back, is a panel that can be removed, remove the screws careful with the bulb, its plugged in behind the panel.
the panel has a vent that allows cold air flow from the freezer, this will often freeze completely shut with ice. let it thaw out, then check to see that the vent opens, or closes when you turn the dial, the best thing is to open it as wide as possible, I even used toothpicks to open the valve even more, its just a thin flap, surrounded by Styrofoam.
afterwards if your fridge is too cold, adjust the real thermostat located in the freezer.
Jan 06, 2011 | Samsung Refrigerators
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
My freezer isnt as cold as it should be, top part of fridge isnt as cold and ice maker isnt freezing water
find the air vent and see if there is anything in front of them to prevent the air from recirculating. ice could be in the vents to,
Apr 13, 2010 | Freezers
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung fridge freezer not cold enough
Hello whiten61,
Welcome,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Huuum
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
