Question about Craftsman 25cc Gas Line Trimmer
I need an owner's manual for a Craftsman 17" 25cc weedwhacker/trimmer. Where can I find it?
    President:
  • Craftsman Master
  • 1,545 Answers
Try going to: www.searspartsdirect.com . You will need your model number. Another place to maybe get one is: http://www.manualsonline.com/
Posted on Aug 20, 2010
Craftsman owner manuals
If you go to searspartsdirect.com and put the model number in it will show you a diagram and on the page is a offering for the owners manual.
Jun 26, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
How to change trimmer line 32 cc craftsman weed ****
Input the model number of your trimmer here and download an owner's manual. The manual will have detailed instructions on how to change the trimmer line.
http://www.managemylife.com/mmh/owner_manuals
May 01, 2011 | Craftsman Garden
My Craftsman Weedwacker, (Model # 358.791010 ) does not start. originally it took about 5 - 10 minutes to start and once it was running, I'd hit the switch from "START" to "RUN" and...
Sounds like a carb problem. You may need to rebuild it. Check to see if your fuel lines inside the tank have rotted. Common problem on Craftsman.
Nov 01, 2010 | Craftsman 25cc Gas Line Trimmer
How do you adjust carb for a Craftsman Incredi-Pull Weedwhacker?
Turn adjustment screw till it almost stops then turn it the other way till it speeds up and starts to stop then turn it half way back and it should work fine but check throttle cable and oil it if it is sticking.
Nov 24, 2009 | Craftsman Garden
I have a crafstman weedwhacker that will start. Once started it will stop as I touch the gas lever. Any suggestion?
check choke for proper connection/check for proper fuel mix / then try to start without air filter-if runs replace w/new filter if problem still check fuel lines for partial blockage/if problem still carb needs service/cleaning
Oct 10, 2009 | Craftsman Garden
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
553 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
