Question about Admiral Washing Machines
I have an Admiral AP4400 washing machine. The adgitator is hesitating. Is my machine a direct drive or belt drive? ajjanz@shaw.ca
Lumpy816
  • 246 Answers
SOURCE: WHIRLPOOL WASHING MACHINE MODEL: 6LSC8255EQ1;
If just the top portion of the agitator does not work, you are likely looking at and agitator dog problem. Yes, it's a silly name for the part, but that is what it says right on the manufactures replacement part. While you are in there, I would also recommend replacing your thrust spacer as well as they get brittle over time. So, once you have part numbers 80040 (agitator dogs) and 8055228 (thrust spacer), here's how to swap them out. First remove your fabric softner dispenser. It should have a blueish/ green ring around it. The ring locks it in place. Lift the ring and the dispenser will lift off. Next, as you look down under where the dispenser was, you will see clear plastic with a black rubber ring around it. There are 2 tabs sticking out of the top of it, just grab these (needle nose pliers would make it easier) and pull it up. Under that you will find a bolt (7/16" if I remember correctly) Remove the bolt and the whole agitator can lift out now. If only the top half comes off, don't worry about it. the bottom half can stay without a problem. As a matter of fact, the thrust spacer sits between the 2 halves. Now, the area where the bolt came out is a seperate piece. It may or may not be held in by two white plastic tabs at the bottom. If it is, just work the tabs off with a small flat head screwdriver. Once this piece is seperated, you will now see your agitator dogs. There is a ring holding them on from the bottom. Slide the ring off and replace all 4 dogs. Wipe any extra fabric softner and shavings from the previous dogs out. Re-assemble in reverse.
Posted on Jul 11, 2008
MARCLAVORIS
  • 110 Answers
SOURCE: washing machine dose not aditate anymore
pull up the agitator, you may need to get a belt wrap it underneath and yank it up, please be careful that it doesnt hit your eye and under the agitator is a coupler or bell that needs to be replaced, it is stripped, loosen the bolt and replace
Posted on Mar 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Admiral washing machine is not spinning.
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing Machine will not spin
It appears your Agitator/Agitator Dogs has failed in this instance.
Posted on Sep 16, 2010
puertobori
  • 7733 Answers
SOURCE: serial # ca 3009268 admiral washing machine the
The what?
Posted on Sep 27, 2011
Washer will not adgitate during wash cycle. what may i look for to try and fix ?
What is the model and model number of the unit? It could be the transmission or the coupling between the motor and transmission. On some models it can even be the lid switch
Jan 04, 2015 | Washing Machines
GE washer model PTAN9455MGG won't adgitate and gives an error code F0
hi, this fault could be slipping belt also brushes on the motor try another program see if it does the same hope it helps
regards
shaun
Nov 16, 2011 | Washing Machines
Washing machine dose not aditate anymore
Mar 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer runs but wont adgitate
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley
Jan 01, 2010 | KitchenAid KAWS850L Top Load Washer
Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Nov 25, 2009 | Admiral AW22 Top Load Washer
My admiral washer wont spin the clothes dry
Probably not getting upto full spin speed, drum may wobble more than usual?
Change the motor drive belt below the machine, tilt the machine 45 degree backwards to access underneath, belt pulls off and replace same way.
Jun 09, 2009 | Admiral AW22 Top Load Washer
Kenmore 70 series adgitates but wont spin the clothes out
this is joyce
The belt is usually found on the bottom or the back, but if you want the sceamatic on your machine go to kenmore.com and put in your model# and download your manuel and find out what you are looking for.
thanks
joyce
Feb 11, 2009 | Kenmore 24032\24036 Top Load Washer
Admiral washer is doing a lot of vibrating...it is level
Possibly a worn drive belt on the underside of the machine, causing the drum not to get to full speed, clothes will be wetter after sping plus vibrates heavily - replace belt.
Tilt machine back for access to underside, simply pull belt off and replace, tension is automatic on motor.
Oct 26, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
