Acer Aspire 5580 wont power up at all
Hi guys
My laptop (Acer Aspire 5580) just went flat and wont show any sign of life. i removed the battery and installed it again. But it wouldn't start up. it was running on vista. used for over an year now. so no point of thinking about the warranty card.
I was using it fine in the morning and locked it and went out without closing the lid.
i tried with new power code, looks like power code is fine, when i connect power code to laptop that little light on AC adapter blinks and when i disconnect it from laptop is stays on.
is this usual in Acer laptops?
  • 2 more comments
  • redium May 03, 2008
    this is an emergency, i have got tones of work piled up. so a solution as soon as possible is very much appritiated. i hope i wud not have to go to a dealer.
    Thanks in bunches.
  • tharlikar Mar 28, 2009
    Mine is Acer 5580 , when i plug out the power jack the green lights in adapter is shining bright. When i plug in the power jack the green lights in adapter flashing. No power lights , and cannot see any sign of power in my laptop. I think my computer got electric short.
  • zainudin Apr 29, 2009
    yes i have the same problem with my acer aspire 5580
  • Anonymous Mar 29, 2014
    My Acer aspire V3-571G will not turn on. There are no lights - nothing. I was using it this afternoon and shut down programs but just closed the lid, leaving it in sleep mode. When I went to plaug it in and turn it on, it wouldn't start, then I noticed none of the lights were on (battery, power, wireless, nothing. What can I do to fix this without having to spend a fortune to get it looked at?
    Scholar:
  • 111 Answers
Remove the adapter plug.
Remove battery and insert again. I use a USB optical mouse, when inserting the battery, the lights will flash a moment. That signs OK.
Try turn on the notebook.
For my 5580, this trick always work. After it is on, I plug in the mains.
Posted on Dec 08, 2008
    Genius:
  • 3,587 Answers
Try to run it without the battery and see how that fares?
Posted on May 03, 2008
It looks like you have a short on your motherboard. I have the same problem with my acer TM2410. :(
And found this website:
http://www.powerjackrepair.org/blinkinglaptopadapter.html
Posted on Jan 18, 2009
My acer laptop aspire 5580 creen monitor goes black, how can i put it back?
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Jun 11, 2012 | Acer Aspire 5580 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
I have notebook acer aspire 5580 that can't power up. I tried to remove battery and supply the power direct from the power adapter but still wont power up. Quetions: Can bios battery can cause this issue?...
Does it have any lights on it at all when connected to the power? If yes then the bios battery could be the problem as it is activated on startup after the lights for battery disk etc show on the front of laptop.
Please rate our help++++ Thanks for using fixya
Oct 08, 2009 | Computers & Internet
My acer 5580 does not detect the electric charging cable.
sounds like your acer adapter has burned up, they tend to get very hot.get a new one.or try a car charger
Aug 23, 2009 | Acer Aspire 5580 Notebook
No power
It is unlikely that not using the surge suppressor did anything. Have you tried removing the battery and using ONLY the power supply? If this works, it is usually a sign that your battery is dead and needs to be replaced
May 16, 2009 | Acer Aspire 5580-6707 Notebook
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
Acer aspire 5570 no power
This problem usually occurs if your laptop undergoes any shock or it falls.
The processor of the laptop hangs and needs to b reprogramed by experts in service center.
Same problem happened to my Toshiba A100
Don't forget to rate my solution Plzzzz...
Acer Aspire 5580 poor battery
Its time for a new battery. After a period of time of using a battery, the amount of charge it can hold depletes. Even if you always have it plugged in. Usually, batteries only last 18-24 months which is sad, seeing how much they cost. I'm a computer tech and see this problem everyday first hand. The best thing you can do is buy a battery from eBay and save yourself a bunch of money. Local retail stores charge up to 3 times as much for a battery. Good luck and I hope this helps..... :>)
May 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5580 laptop unable to power up fully
remove battery and use the ac try it then, if that doesn't work remove everything possible cdrom,memory,battery,pc1.gif cards and try it again, if still fails try wiggling the ac cord at the input
Jan 24, 2008 | Acer Aspire 5580 Notebook
Computers & Internet Logo
988 people viewed this question
David Payne
David Payne
