Wireless card unresponsive, computer says it isn't connected.
    Genius:
  • 3,587 Answers
Check this in the control panel, under system device manager, or go through wireless setup again
Posted on May 03, 2008
Maintain wireless connection at school, is ok everywhere else...
There are some points to consider: 1. It could be that your computer is restricted from the school's wireless access point. 2. It could also be that the wireless adapter is old and might be needing an upgrade. 3. You could also try to re-type the school's wireless password in your computer is there is any.
May 21, 2013 | Toshiba (PA3212U) Wireless Adapter
My wireless network isn't working
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 19, 2012 | Toshiba Satellite Pro L300 Notebook
Hard wire computer works roku works [ wireless] But my laptop [wireless] isn't
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 08, 2012 | Linksys Wireless-G WRT54G Router
Unresponsive wireless broadband virgin media
please login to your browser via 192.168.1.1 and change the wireless channel to either 1 or 11.
also if your wifi encryption is set to WEP please change it to WPA2 or WPA.
Feb 22, 2012 | NetGear WGR614 Wireless Router
Wireless adapter not conncted
Either there isn't a wireless card on board or the card is bad.Also the card may not be installed.Did it work before?If it did the card may be defective or was uninstalled some how.Check if it shows in device manager or if it shows a caution symbol.
Dec 02, 2011 | HP G62144DX Laptop
Nt get a wireless connection
You need to replace the Wireless NIC card
Nov 27, 2011 | Computers & Internet
I had to reinstall my vista os on my dell inspirion 1525 and now the wifi connection will no go on. I h ave tried turning on and off the toggle switch, the BIOS is set to enabled for wifi, I have tried...
There is a strong chance that the wireless card inside is bad. I work at a computer repair shop and work mainly with laptops. It isn't uncommon for wireless cards to go bad, before their "time". Usually Dell's have access panels on the bottom of the laptop where you can see the wireless card. It will have 2, sometimes 3 small wires plugged into it. Usually dell' use Dell brand cards, which are really repackaged Broadcom wireless cards in most cases. In your situation, write down what the model number is, go to another computer, look up that model on ebay, buy one, replace it.
Oct 04, 2011 | Dell Inspiron 1525 Laptop
Can't find wireless on key on Amilo fujitsu
The left-most silver button by the power button is the wireless on/off key. The other two launch your default web browser and email client.
Oct 17, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
The mouse keeps becoming unresponsive and turning off at random
What type of mouse is it? Wireless or wired USB mouse?
If it's wireless, replace the battery with new one or you may try connecting the USB wireless adapter (that came with the mouse) into another USB ports of the computer.
If it's a wired mouse, try connecting it into another USB ports of the computer. Or you may use it with another computer just to isolate the problem. If you would get the same problem even after connecting it into another computer, then I could say that the mouse needs repair.
Hope this helps!
Aug 21, 2009 | Logitech Computers & Internet
Computers & Internet Logo
David Payne
David Payne
