Question about Whirlpool RBS275PD Electric Single Oven
Good evening. Have a repair tech that cannot figure out problem and is trying to upsell to a new oven. We have a whirlpool rbs275pdb11 whirlpool oven that we replaced both the control board and the thermal base (?) and are still receiving the error message E1-F2. We cleaned all the connections, the ribbon, etc. Husband is an electrician and he checked all voltage. The tech that came out did not know how to fix and said we now need to replace the keypad (front portion of oven) but still no guarantee it would work. That is when he tried to sell us a new oven. Any help would be greatly appreciated. Thank you.
  • 15,935 Answers
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%^*(
Posted on Oct 01, 2010
  • evansx Oct 27, 2010
    you don't need a "professional" to solve this problem or even to order any parts. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper. good luck.
I get a start? when pressing start and oven wont come on my whirlpool electric oven
Terrence, Could be defective oven element, control board, etc. have a good tech. diagnose and estimate repair. Check the attached links trouble shooting,instruction and guides for electric oven, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Whirlpool Oven Won Turn on
Troubleshooting Guide for Whirlpool Electric Range
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Jul 29, 2016 | Whirlpool Ovens
What should an oven temp sensor's ohm reading be if it's at room temperature and not faulty? Whirlpool 30" electric range, model number WFE361LVD Bake element and broil element do not heat...
The oven sensor should be between 1000-1200 ohm's at room temperature or roughly 1080 ohm's. I would place the Tech Sheet here but Whirlpool will not allow me to post their manuals or Tech Sheets. You are welcome to the Tech Sheet HERE I hope this helps Thanks, Sea Breeze
Oct 22, 2011 | Ovens
I have a whirlpool gbs307 oven and after completing a self-clean cycle and wiping it clean after it cooled, it won't heat at all. Any ideas?
HI,
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
thank you,
vijay
Sep 29, 2009 | Whirlpool GBS307PR Electric Single Oven
Whirlpool glass door exploded in my face! A serious defect!
I would go to a Lawyer unless you have a serious voltage problem. Whirlpool makes pretty good appliances. To have probems with all of them is very unusual. Look for a comon problem. You have not stated your outher problems. I have heard about oven glass breaking with no reason.
Sep 21, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven door glass repair
Get a tech to do this. You will end up breaking the replacement glass if you are not careful. It is too hard to explain to replace the glass by not seeing what you are doing.
Jan 24, 2009 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Gold double electric oven Model GBD277PDB1 lights
in answer to your question no not that your tech is bad his stuff is honest most of the costs are parts what i would is do contact whirlpool cust assistance and talk to them dont confuse cust assistace also known as custmer relations with with customer service they are not the same cust relations could give you the parts and then you can pay labor if your going to keep the oven see about a service contract on it ge or whirlpool both have good ones whirlpool cares about there cust so be nice when you talk to them like my mom had whirlpool ive allways had whirlpool but i just dont understand whats going on with this oven etc good luck
Dec 29, 2007 | Ovens
Whirlpool RBS275PD Electric Single Oven Logo
98 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
