Yamaha M-80 natural sound power amp.
My repair man has determined a few transisters to be defective, has replaced them, and when he fired it up, they blew out again. So he has asked me for a manual or schematic for it, but do not have either. So my question is a acquire them somewhere to help aid him with the repair. Can you help me, please?
Have you resolved this issue wit with M80 Amp? This amp has a unique DC path and if it is several years old, some caps and diodes go bad. In most case the power transistors are not bad when the protection light comes on. I bought my M80 in Germany back in the mid eighties and had to do some repairs in the last 5 years but it still works hard.
Posted on Sep 01, 2008
My Yamaha RX-673 not powering on. On standby mode
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired not problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
Yamaha RX V-795
Start with the process of elimination...disconnect speaker wires and (obviously) speakers. Does the amp still enter the protection mode? If not then check wires and speakers for issues. If the results are unchanged, look for protection circuit problems or "overlooked" power supply issues. Good luck...
Jun 01, 2014 | Yamaha Audio Players & Recorders
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
Power went out no power to ILO-32hd
yes posible power supply is defective if fuse blow then could be defective fet transisters as well shorting best way is to replace complete board if it was surge from electicity.
Mar 02, 2012 | iLO 3200 32 in. LCD Television
2005 GMC CANYON BLOWER MOTOR ONLY WORKS ON HIGH?
Ok I'm going to be honest and tell u the truth, this exact thing happened to me. There is a 4 part pigtail relay plug connecting to a transister, the high only works because it bypasses the transiter and go directly into the fan power, but setings 1,2,3 eventualy and no longer usuable due to the transister input to the specific speed burning out, u can lose differnt speeds and differnt times depending on which speed u prefer the most. If u prolong the repaire even longer it will cause a short and u will burn fuses or even the main fuse in your fuse box. How to fix. I didn't perform the repair but I read that the relay and the pigtail are both located next to the fire wall. It cost me a few hundred dollers, and only 35 dollers for labor, the rest was the transister and the pigtail being the most. Sapposidly it was vary easy to get to, and if you look in a haynes repair manual it will give you the electrical scymatics of the wireing for the fan blower control.
Aug 31, 2010 | 2005 GMC Canyon
Cannot Power Up, Sometimes can
i had a real nice yamaha natural sound receiver and the relay that switched it on went bad a lot..... try the relay???
Apr 26, 2010 | Yamaha RX-V650 Receiver
Power amp outputs no sound
No one could determine the extent of the problem without placing hands and eyes on the unit.
Have you checked the Yellow Pages or online equivalent?
Mar 24, 2010 | Audio Players & Recorders
When we turned on our large screen panasonic tv there was a pop, then no sound. The picture is fine. It is several years old. Not a flatscreen. Large speaker at the bottom.
It sounds like the power transister for the amplifier has blown. Inside, it is usually the largest transister connected directly to a heat sink. It will require the ability to solder (and unsolder) in order to affect the repair. Look up the transister from its code inscribed on the case to find a replacement. Power transisters are usually not very expensive. You can go to this link to see what a typical power transistor looks like.
http://innovision-group.net/catalog/index.php?cPath=1_37
Jan 26, 2010 | Televison & Video
Power acoustiks amp wont get off protection mode? how do i reset it? please help me i tried everything.
Hello nfox1987,
First you need to determine if the amp is defective or if something else is causing it to go into protection, most often a short in the sub or amp wiring.
Disconnect the sub(s) from the speaker output terminals and the RCA inputs from the head unit, and test if the amp powers up OK. If it does, the problem is in the sub(s) wiring or voice coils, or in the RCA inputs to the amp. Reconnect each one-at-a-time to determine exactly where the short is and repair or replace the defective wiring or unit. If it doesn't power up with the inputs and sub(s) disconnected, the amp itself is most likely defective.
Hope this helps.
Jul 15, 2009 | Sony XM-475GSX Car Audio Amplifier
1,044 people viewed this question
 Grubhead
Grubhead
