Question about Galaxy Radios DX-99V 40-Channels Base CB Radio
The frequency goes off track once in a while till I bump it on the bottom and it goes back to 27.185 but can't figure out why it jumps tracks and neither can 6 so called cb repair men one who has a college degree in electronics
10.249 Mhz frequency can on left side of board by "TR24" going bad or loose. Check it out I've had a couple 99v's that's what it was. GOOD LUCK!!
Posted on Aug 25, 2010
  • 29 Answers
Hi malone
This sounds like a ground maybe a little loose ground in side the radio. Let me ask you if you can still use the radio with it off of freq. or does totally loose its brains with no rx or tx on right channel while it is displaying the freq. drift? reason i want to know is there is alot circuits that are involved in this radio for both the display and actual freq. error.
Posted on Aug 23, 2010
Cd/dvdrw player door of track,
You'll have to remove the top casing. Once the casing is off you'll see the drive bay.
Jun 27, 2008 | Televison & Video
The driver side window on my 95' Chevy K1500 goes off track if it is rolled completely down. I get the feeling I am missing a stopper or something that should stop the window before it goes all the way...
Yes there should be a stop if the window is power. You may be missing a guide also.
Someone will need to pull the door panel off and take a look at the tracks.
Aug 27, 2013 | 1995 Chevrolet K1500
How to put side doors back on the track so they can open and close without any problems
this happened on my 87 stretch caravan once I had to remove the bottom slider track and slip the little wheel back in the track and then bolt track back on one half and then slide door to get other half
Dec 19, 2009 | 1999 Chevrolet Venture
The driver's side power window is skipping or
Most likely the rail has come loose inside the track you can drill a hole and put a #20 nut and screw in it to hold it tight so it won't move the track is the most common thing to wear out on the window. once you repair it it should be fine check all four corners the most common break is in the lower right side looking at the door with it open. Also the track will come loose as well and that can cause you the same problem, with the cover off the door operate it so you can determine which area it is jumping from and then fix it. also lube the tracks with synthetic grease to keep it from being hard to roll up also lube the rollers in the bottom of the track.
Jul 17, 2009 | 1999 Chevrolet Blazer
Locked out of vehicle Broke out sliding center section
Put the top part first, and the lift it until you can put the lower part in and lower it.
Mar 29, 2009 | 2005 Dodge Ram 2500 Truck
My 2006 Camry's CD player jumps track
You have the RANDOM feature engaged. Look at the player and push the button under the word "RAND" off. The RAND is just that: random tracks.
Jul 25, 2008 | 2006 Toyota Camry
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Jumping Tracks when using "Next" control
find the "reset" button (this button usual is very small) find it in front of the control panel, if the control panel is removable find "reset" button after removed
Feb 02, 2007 | Sony CDX-T69 6-Disc CD Changer
Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
147 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
