Question about iLO 3200 32 in. LCD Television
MY ILO HAVE A PROMBLEM IN THE POWER BUTTON IT CUT OFF AND TRY TO COME BACK ON.
  • 11,361 Answers
Not likely to be the power switch itself, more likely to be in the power supply or it shutdown to protect itself due to short circuits in the power supply or in the backlight inverter board, you can try disconnecting the power cables to the inverter board to see if you can get the sound but no pictures.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 21, 2010
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
Ilo 32 in lcd won't power up.
may be you need to replace the switch
Mar 17, 2008 | iLO 3200 32 in. LCD Television
My ilo tv will not change from channel 3. The
You may have accidentally pressed 'Favorite' on the remote which will lock the controls. Try pressing 'Favorite' to unlock the controls.
Jul 10, 2010 | iLO 2600 Television
My ilo rc-370c wont turn on.the red light just blinks????????
If you get a flash on the red light when you try to turn it on and hear a popping noise. Unplug it then use a hair dryer to heat the inverter up on the right side (power button side) of the tv (up through the vents in the back for 10-15 mins). Plug it back in and turn on.
Apr 05, 2010 | iLO 3200 32 in. LCD Television
My ilo tv will not turn on by the remot or power button
Remove back cover. Check to see if the fuse is blown. If not, check power from power supply to main control circuit to see if there is power. If not, the power supply is probably bad.
Oct 26, 2009 | iLO LCT32HA36 Television
My ILO tv will not turn on. It has power. Is
i had the same proble..there is a 120v 4 amp fuse below where the power cable connects to the circuit board chances are this is blown
Jul 08, 2009 | iLO 3200 32 in. LCD Television
ILO 27" LCD don't start up.
check batteries in remote, does it click back into stand by when u press power button?
Dec 11, 2008 | iLO 3200 32 in. LCD Television
ILO wont work
One of two things..try a new battery...or it's possible that your button lock button is in the lock position ( look under the power button make sure it is pushed up)
Dec 24, 2007 | iLO (2 GB) MP3 Player
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Ilo 2600 remote control code
I finally found a direct tv remote code for my Ilo television. It was 10171. Others you can try that were for Direct TV remote: 10154 10236 10463 10180 10178 10019 10177 10623 10179
Sep 09, 2006 | iLO 2600 Television
iLO 3200 32 in. LCD Television Logo
32 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
