Question about Whirlpool Dishwashers
My dishwasher is 1 1/2 years old and the maintanence buy said I need a new motor. I looks like it is working just no water. I know that there has been recalls on motors could it be that? Georgette
  • 139 Answers
Well if the motor is running not humming it needs water to work so prob water valve is not opening or their is a water safty switch that could be stuck it in the tub usually in the front
Posted on Aug 21, 2010
I smell my motor. Is it worth replacing, or buy new?
5 years seems short for a major appliance designed to give 10 years or more of service. I'd say it's worth repairing yourself.
Just make sure it is the motor, then dig a little deeper to find out why it failed. It can be from being bound up because of a jam in the pump, a leak causing the bearings to freeze, or in the case of inductive motors a failed starting/run capacitor.
I've seen failure of the waste water gate/valve solenoid due to a timer issue. You'll have to do your detective work and once you know exactly the part that is eminating the smell, you will have a path to backtrack from.
Remember, water and electricity don't mix and shut both off before working inside the dish washer!
Jan 30, 2016 | Kenmore Dishwashers
Replacement motor arrived. Slightly different. The old motor had a proprietary kenmore electrical connection.
Sears Appliance - Dishwashers - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Dishwashers
Rating: 1 - ‎80 votes
We have ordered new wheels but the price for plastic wheels seemed a little high ....Hose came loose, water pours out and into my basement, pump slips out of slot ..... I will NOT be buying another Kenmore dishwasher when I do replace it.
Sears Appliance - Dishwashers ' Page 2 - ConsumerAffairs ...
We bought a Kenmore dishwasher from Sears a little over 1 year ago and ....Switchboard being replaced 3 times, motors and wiring being replaced they still will ....Another tech came out and said "Well they didn't program the motherboard" so ...
Kenmore Dishwasher Parts - PartSelect
www.partselect.com/Kenmore-Dishwasher-Parts.htm
Dec 22, 2015 | Kenmore Dishwashers
My dishwasher is not filling with water. It is about 10 years old. Should I try to get it fixed or buy new one?
Not a big deal either the float is stuck or you need a new water valve the float is located inside the door on the front left or right side wiggle it around and then try it
Nov 08, 2013 | Whirlpool Dishwashers
Dish water is not working. Water fills but no noice after that.
it's obviously sounds like your pump has gone, but considering the age of the machine, it would probably be best to get a new machine, that way you would have a 5 year warranty with it aswell so it's win/win really!
Jan 05, 2013 | Dishwashers
Water on floor after Kenmore dishwasher runs
you could fix this, however the price of repair will be 1/2 of the price of a new dishasher.  I would suggest you buy a new oneand not waste money on a six year old dishwasher.  find a good scratch and dent model.
Mar 15, 2009 | Kenmore Dishwashers
Dishwasher not working
Will be buying a new machine, since we found out their lifespans are between 8-12 years. Don't want to keep on sinking money into fixing the machine or asking for advice.
Jan 02, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Rust on the inside of the dishwasher door
It's time for a new dishwasher. If you are seeing rust and you don't know how old it is then by all means buy a new dishwasher. My experience is that a dishwasher is to live about five years. Then the problem grow to leaks on your floor and you will discover the leak a month later and you will be replacing sub floors etc. Buy a new quieter machine for less than $400. bucks. Check out Sears, Lowes or Home Depot for your best buys.
Feb 02, 2018 | Dishwashers
Dishwasher will not start.
You more than likely have a faulty motor on your dishwasher.  This would be the main motor that pushes the water through the spray arms inside the dishwasher.
There should be a tech sheet behind the control panel of your dishwasher or maybe behind the lower kickplate.   This will give you the readings for the motor so you can test with a volt meter.
Give this a look first.  If the motor tests good then you may be looking into replacing the timer.
Thanks, Bill
Nov 26, 2008 | Dishwashers
Dishwasher
Hello tytsai2005
Welcome,
You said,At the end of a wash, some water still remains at the center of the bottom
You have a clogged dishwasher drain, or drain line.
Otherwise your Caloric's pump is pooping out on you!
Is the model # CDC550CL or CDC550CW ?
Here are 4 things that I believe can be the reason for your machine not pumping all the water out!
1. Defective Motor
print.gif Print save.gif Save to list email.gif E-mail to a Friend help.gif Diagnostic Help Rate Article Helpful Not Helpful Was this helpful?
How can we improve?
The water pump is driven by the drive motor. If the motor is defective, the pump will not operate and the water will remain in the tub.
2. Defective Pump
Most but not all dishwashers incorporate a reversible motor. By using a pump impeller and wash impeller, the action of washing and draining is accomplished by the reversing of the motor. If the drain impeller in the pump is defective, the water will not drain. Check the pump impeller for proper operation.
3.Drain Line
Check the drain line for kinks. If the line checks out visually, it could be an obstruction in the line
4.Garbage Disposal
If a garbage disposal has recently been installed, make sure the knock out for the dishwasher drain hose has been removed. You should also make sure that no items under the sink have been pushed into the drain hose. Any kink or crimp in the hose can cause it to stop draining.
How old is the dishwasher ?
Here is an interesting article I just read, that you may find interesting
Repair or replace?
When to pull the plug on your old dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your dishwasher,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your dishwasher is under warranty or less than four years old ,
paying for a repair makes sense.
Note that dishwashers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your dishwasher is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new dishwasher.
Data also shows that it doesn't pay to fix a less-expensive dishwasher
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of dishwashers you replace are likely to end up in a landfill.
Let me know how you do!
Thanks for giving me the opportunity to help!
Huuum
Please do not forget to give a rating before you sign off!
Oct 20, 2008 | Caloric CDC550C Dishwasher
Dishwasher problem
Hello ramsey06,
Welcome,
You said , dishwasher starts everything is going OK. the water is going but then it stops and does not finish.
First: this is what Whirlpool says!!
And after this Is what the repair manual says when I looked it up for you!
Dishwasher is not operating properly
1.Dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
2.Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
3.Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
4.Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
5.Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
6.Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
7.Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
___________________________________________________________
BUT, the repair manual says this
Faulty Pump and Motor Assembly Some models that will not wash or drain often have a faulty Pump and Motor Assembly. If the motor is receiving power from the timer and it is not operating that is the case.
Temporary Work-around:
With the power turned off to the unit, sometimes it is possible to manually rotate the cooling fan on the motor assembly. In certain situations where the dishwasher has set idle for a period of time, this may free the bearings enough that the unit will begin to operate. Where this works as a short term solution in some cases, it is often a sign of things to come. The frequency of the motor seizing will increase until it will simply no longer work.
I think this is a hands job that needs service and hands on attention!
I hope it's not the motor or pump!
How old is the machine?
If they tell you it is an expensive motor then you need to know this!!!!
Here is an article I just read!
If the dishwasher is old it will not pay you to repair the
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
Let me know how it goes!
Huuum
Oct 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
47 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
