Home | Sceptre | X9G Komodo IV (Black) 19 in. Flat Panel LCD... | Sceptre X9G Komodo IV ...
Sceptre X9G Komodo IV  19 in. Flat Panel LCD Monitor
Problem for Sceptre X9G Komodo IV (Black) 19 in. Flat Panel LCD...
By Mutumbo II on May 03, 2008
Display went out, only comes on for about a second when power button is pushed off and on. Opened monitor up, looks like two coils labeled L1 and L2 are burned at the top. The two caps most people are talking about c114 and c115 look just fine. Monitor is about 3 years old.
Same Problem
Jan 27, 2009
-   Mine will turn on when it's not plugged in to the comp and will show "non connection". But! When it's plugged in it's the same as I've read here. push the on button and it immediately goes out. Now, I can replace parts but I'd sure like to know what part to replace! Any Suggestions???-   tjnstacey
Oct 15, 2008
-   i had same problem, took monitor apart and found one solder connection on inductor had never been solderd in the bath, sunk the solder in socket and has been working now
-   Guest
Oct 11, 2008
-   Me too!  Same problem described here ... Using dual display (both same Sceptre X9G Komodo II) about 3 years old now.  Just recently the one monitor display would be dark at startup.  For a few weeks I just powered it off and back on and it would then stay lit until the next time.  However, now the screen will only stay on for a second (long enough to display the desktop) and then shuts itself off.  Blue light is lit.  Connections are good.  I switched DVI cables to troubleshoot, and the problem remains with the same monitor so I know something's wrong.  I can't seem to find manufacturer's info online anywhere -- anyone have it?  Do you really think it necessary to send back or if I'm technically savvy enough could I manage this fix?  Please advise.  Thx.-   sunsister
Jul 04, 2008
-   I have the same problem, started maybe a month ago on a monitor purchased in Feb 2004. -   dpilloff
Jun 09, 2008
-   same thing, same monitor Sceptre X9G Komodo IV 19 in blue power light blinks and monitor only stays on for about 1-2 seconds, after tuned on
maybe it has a reboot option??? I'm just guessing!! any suggestions?
-   Guest
Best Solution
posted on Jul 15, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the exact problem with mine when I just bought it -- It would turn on for a second or two and the screen would go blank. I had to send it back to the manufacturer to get it fixed. It was a minor problem and they just replaced a part and sent it right back to me. It has worked perfectly since then. Hopefully yours is still under warranty. fyi -- I think that it was a problem with the power supply unit.
Solution #2
posted on Oct 27, 2008
Not Rated)
wr450f
Rank: Apprentice
Rating: 0%, 0 votes
I found the power supply/inverter on Ebay for $40.00.
It is an LM004 Rev2 for the X9G Komodo VI.
It came from Germany.
I had the inverter section go out.
I had replaced all the caps. The capacitors were not the problem.
Was this helpful?
Yes
No
Solution #3
posted on Jun 04, 2008
Not Rated)
JULIANFIX
Rank: Guru
Rating: 86%, 592 votes
check out any dry solder or burnt and re solder it , hope it helps AJ
Was this helpful?
Yes
No
Popular Solutions for Sceptre X9G Komodo IV 19 in.
Questions and Unsolved Problems for Sceptre X9G Komodo IV 19 in.
Do you recommend Sceptre X9G Komodo IV (Black) 19 in. Flat Panel LCD Monitor?
Answer
Answer
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any... (More)
Answer
Tried another LCD monitor on my system , it works fine. Can anyone help?
Answer
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts... (More)
Answer
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sceptre X9G Komodo IV 19 in....:
Top Monitor Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
