Question about HP Photosmart C6180 All-In-One InkJet Printer
I have an HP Photosmart C6180 All-In-One, The message on it reads Error 0xc18a0101. It will not allow me to print. It says that there is some ink problem. What do I do to fix it?
  • 100 Answers
An ink system error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Posted on Mar 28, 2011
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
"Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0101 Turn power off, then on again."
The first problem is you have an ink jet consumer printer. Go to their support site and search that error code. That may help, but don't count on it. HP is notorious for selling defective products and have lost more than one class action suites. you can try these steps http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785&tmp_track_link=ot_search
But it could also be the error for when the ink resovors are full in the bottom of the machine. It will stop working by design then. If it were to over flow you would see where all that ink went you been buying, so they stop the machine before that happens. Best advice is take it to the nearest dumpster and deposit it inside it, and buy a laser printer. It was the best thing I ever did.
Jun 17, 2014 | HP Photosmart C6180 All-in-One Printer,...
Error: 0xc18a0101 I just change a ink and this
It seems some one else has had your problem. http://www.fixya.com/support/t1132877-oxc18a0101_error_message_c6180_all_in .
Jan 15, 2010 | HP Photosmart 3310 Printer
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure Error: 0xc18a0101
hiii
You have to check ur printer connection status if it is ok then you can restart the printer and run it again on your system.
and if still your problem is not solved then can visit for free technical support on http://techbuddies-robin.blogspot.com/2009/06/free-technical-support-regarding.html
Jun 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 all in one, does not copy or print anymore.
put the old cartridge back, if there have same error message then tell me what error message is, if not that's mean new cartridge is defect.
Dec 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
