Question about Canon EOS 7D Digital Camera
Hi there, i have this canon eos 7d camera with the final firmware. also final version of eos utility is installed on my pc. my problem is, when i connect the camera to my pc with a usb cable eos utility can not recognize the camera. when i use a card reader i can see the pics i took with the camra but i need to connect the camera to my pc so i can make timelaps shoots. any idea to solve this problem? thank you.
    Brigadier General:
  • 11,967 Answers
Have you tried other USB ports on your computer? Also, try these: Solution: Windows should automatically recognize your digital camera and prompt you with a list of possible actions, such as viewing the pictures stored on your memory card. Sometimes, this recognition takes several minutes, especially if you're plugging in the device for the first time. If, after waiting a reasonable amount of time, you are not prompted with actions for your digital camera, ensure that your camera's batteries are charged and that your camera is turned on, as many models require the camera to be powered in order for the computer to access its contents. If these things check out, try plugging your camera into a different USB port. Next, go to the Start menu and click My Computer (in Windows XP) or Computer (in Windows Vista and Windows 7) and then see if your device is listed under the Devices With Removable Storage section. If it is, double-click your camera's icon to interact with it. If not, try the following suggestions.
It could be that in order to use your digital camera with your computer, you must first install the software that came with your camera. If you can’t locate the software disc that came with your digital camera, you may be able to download the software from the manufacturer’s Web site.
If none of the above solutions solves the problem, you may need to enable your camera in the Device Manager. In Windows XP, click the Start menu and choose Control Panel. Click Performance And Maintenance, click System, and choose Device Manager under the Hardware tab. In Vista and Win7, click Start and choose Computer. Click System Properties at the top and then choose Device Manager from the left menu. Locate and expand the Disk Drives entry, right-click your camera’s name, and choose Enable. Once enabled, your camera should be recognized and listed in My Computer. If your camera is still not recognized, we suggest you contact your camera’s manufacturer for additional suggestions.
Posted on Aug 20, 2010
Testimonial: "Thanks a lot for your effort and attention but I had tried every single one of your suggestions before but nothing worked."
  • abidin61 Aug 22, 2010
    Thanks a lot for your effort and attention but I had tried every single one of your suggestions before but nothing worked. I tried to attach my camera to another EOS 7D owner's computer and it did not work there either. He can connect his 7D to his computer but when we tried to connect my camera to his laptop with the same cable it didn't work.
    So we came to this conclusion: Probably the firewire socket of my camera is not working. I will take it to a repair shop on Monday.
    Thanks a lot.
  • MajorLeagueR Sep 15, 2010
    i have had this problem with two computers.. one with vista 64 bit n one with win 7 32 bit... on another 64bit win7 i succesfully used all of the cameras fucntions.... very strange!!!
Error 99 ?
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 14, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Tip
Canon Rebel XS Firmware Update MAC Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Doesyour Canon EOS Rebel XS / Canon EOS 1000D suffer from either of thefollowing error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which theLCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. Themessage, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears onthe camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from theactual language setting.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
Follow this link to download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
on Apr 15, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Tip
Canon Rebel XS Firmware Update WIN Models: Canon EOS Rebel XS / Canon EOS 1000D...
Does your Canon EOS Rebel XS / Canon EOS 1000D suffer from either of the following error messages that prevent it from normal operation?
To download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
O que faz dar o erro busy na canon?
I can help you fix the BUSY Error of your Canon EOS 1000D.
I hope that helps.
Jan 22, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera saying busy
I hope that helps.
Jan 20, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Tip
Canon Rebel XS Firmware Update PDF Models: Canon EOS Rebel XS / Canon EOS 1000D ...
Would you like a digital, searchable, pdf version of the Canon EOS Rebel XS / Canon EOS 1000D Firmware / Installation Guide?
I hope that helps.
______________________________
Canon busy signal busy signal after take a picture
I hope that helps.
Dec 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Hi. I just tried importing my images from my canon 7d to my mac computer using the eos utility and it quit unexpectedly. I then tried again and any option I chose would reply with the word busy on the...
Based on the information you provided, it seems that issue is with the EOS Utility itself.
Uninstall the EOS Utility, restart the Computer and then install the EOS Utility again.
This should resolve the issue.
If the issue persists, check for any update for the EOS Utility and install the update to resolve the issue.
Good Luck!!!!!!!!!!!!!
Nov 23, 2009 | Canon Computers & Internet
Camera is locked with continous busy error, will not download or take pictures
I hope that helps.
Oct 26, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Error busy canon eos 1000
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Sep 20, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS 7D Digital Camera Logo
488 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
