Question about Magellan eXplorist 400 GPS Receiver
Compass how do cal. the compass in the 400
I have read the 400 has no compass. Only 600 and higher...
Posted on May 09, 2008
2 Suggested Answers
  • 3422 Answers
SOURCE: explorist 400 gps
Hi again,
Sorry for the trouble.There was a software problem which caused this trouble.Anyways i'll give you a owners manual and you can figure it out.
Waiting for your reply
Posted on May 03, 2008
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
Explorist 400 gps
Hi again,
May 03, 2008 | Magellan eXplorist 400 GPS Receiver
The word cal is displayed above the temperature display what is it?
This is the self-calibrating compass.To calibrate make one or two 360 degree turns,the symbol should go off and the compass reading will be displayed.
Jun 15, 2011 | 2008 Chevrolet Impala
Compass direction wrong
Compass Calibration
Before calibrating the compass, drive the vehicle to an area that is magnetically clean or free of large metallic objects. Verify there are no magnetized objects on the inside or outside of the vehicle close to the mirror.
Start the engine.
Press and hold the switch for the compass, which may be depicted as COMP, COMPASS, or On/Off (w/UE1) depending on the type of mirror on the vehicle, until the letter "C" or "CAL" is displayed.
Drive the vehicle in circles at a speed of less than 8 km/h (5 mph) until the "C" or "CAL" is replaced by a proper vehicle heading. The calibration procedure is now complete.
Magnetic variation adjustments are required when the compass displays a constant error in heading. Variation is the difference between magnetic north and true north due to geographical location.
Nov 09, 2010 | 2004 GMC Envoy
Built in electronic compass on 2004 GMC Envoy is giving the wrong directions
Try the following;
Compass Calibration
Start the engine.
I have 2002 Yukpn Denali XL. There is a OC code that appears in the rear view. What is the cause of this and how can I fix it?
The "OC" indicates your compass is "Out of Calibration". Below is the proceedure to recalibrate your compass.
Compass Calibration
The compass may need calibration if:
 After five seconds, the display does not show a
compass heading (N for North, for example), there
may be a strong magnetic field interfering with the
compass. Such interference may be caused by a
magnetic antenna mount, magnetic note pad holder
or a similar magnetic item.
 The compass does not display the correct heading
and the compass zone variance is set correctly.
In order to calibrate, the letters CAL must be displayed
in the mirror compass windows. If CAL is not
displayed, push in the COMP button for approximately
eight seconds or until the letters CAL are displayed.
The compass can be calibrated in one of two ways:
 Drive the vehicle in circles at 5 mph (8 km/h) or less
until the display reads a direction, or
 drive the vehicle on your everyday routine and after
several turns the compass will become calibrated and
will display a direction.
Good luck.
Oct 23, 2009 | 2003 GMC Yukon XL
Compass calibration Hummer H2 2005. Compass shows "CAL" sign and the standard procedure described in Owner Manual doesn't help. What else? Thanks!
There is an offset that is used. I need to know what area of the world you live in. Then there is a digit that you set the compass to. and it is then CLOSER to actual.
Sep 01, 2009 | 2005 Hummer H2
Compass out of whack
You need to recalibrate the compass. The procedure is in your owners manual. Here are the basic steps.
First, you will need to verify that your compass zone is set to your current geographic location. Since I do not know where you are located, I cannot tell you the code. They are listed in the manual. (For example, So Cal is zone 5.)
Second, here is the compass calibration adjustment procedure:
Perform this adjustment in an open area free from steel structures and high voltage lines. For optimum calibration, turn off all electrical accessories (heater/air conditioning, wipers, etc.) and make sure all vehicle doors are shut.
1. Start the vehicle.
2. To enter the compass calibration mode, press and hold the button for greater than eight seconds. The display will then show CAL in the display window.
3. Drive the vehicle slowly (less than 3 mph) in circles until CAL indicator turns off. As many as 5 complete circles may be required.
4. The compass is now calibrated.
Dec 19, 2008 | 2005 Ford F-150
Magellan eXplorist 400 GPS Receiver Logo
80 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
